Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. #1
    Attempted to update firmware... now I'm stuck
    A while ago I printed the parts for the Itty Bitty Double FLEX V2Extruder and picked up the hardware to make it... Finally got around to putting it all together and am now stuck...
    I have the RAMBo board as my setup and cannot for the life of me get a working configuration to upload and get either extruder working.
    Is there a good place to start? Or does someone already have the Rambo version of the firmware for this setup available for me to start working with?
    Setup:
    12" Makerfarm frame
    IBDFlexV2 with E3Dv6 extruders.
    Thanks in advance.
    --PS
  2. #2
    Ok so I have updated to the nightly build of Marlin - I have attempted to fix my issues but I still cannot get the the servo for the z probe to extend/retract.
    I have tested the wiring and it gives the appropriate readings on my multimeter but something is not right.
    I could really use some help getting this going.
    My setup is still as above - 12" Makerfarm, IBDFlexC2 with the E3Dv6 hot ends.
    The plastic bits were printed when my printer was working and the motors/metal bits were bought from Clough42.
    Configuration.h
    Code:
     * Marlin 3D Printer Firmware
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    #define CONFIGURATION_H_VERSION 010100
    // User-specified version info of this build to display in [Pronterface, etc] terminal window during
    // startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
    // build by the user have been successfully uploaded into firmware.
    #define STRING_CONFIG_H_AUTHOR "(Plackslayer, Dual)" // Who made the changes.
    #define SHOW_BOOTSCREEN
    #define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
    #define STRING_SPLASH_LINE2 WEBSITE_URL         // will be shown during bootup in line 2
    #define SERIAL_PORT 0
     * :[2400, 9600, 19200, 38400, 57600, 115200, 250000]
    #define BAUDRATE 250000
    // The following define selects which electronics board you have.
    // Please choose the name from boards.h that matches your setup
    #ifndef MOTHERBOARD
      #define MOTHERBOARD BOARD_RAMBO
    #endif
    // Optional custom name for your RepStrap or other custom machine
    // Displayed in the LCD "Ready" message
    #define CUSTOM_MACHINE_NAME "PlackPrint 3D"
    // @section extruder
    // This defines the number of extruders
    // :[1, 2, 3, 4, 5]
    #define EXTRUDERS 2
    // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
    // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
    // For the other hotends it is their distance from the extruder 0 hotend.
    #define HOTEND_OFFSET_X {0.0, 25.50} // (in mm) for each extruder, offset of the hotend on the X axis
    #define HOTEND_OFFSET_Y {0.0, 0.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
    // @section machine
     * Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
     * 0 = No Power Switch
     * 1 = ATX
     * 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
     * :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
    #define POWER_SUPPLY 0
    #if POWER_SUPPLY > 0
      // Enable this option to leave the PSU off at startup.
      // Power to steppers and heaters will need to be turned on with M80.
      //#define PS_DEFAULT_OFF
    #endif
    // @section temperature
    //============================= Thermal Settings ============================
     * --NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
     * Temperature sensors available:
     *    -3 : thermocouple with MAX31855 (only for sensor 0)
     *    -2 : thermocouple with MAX6675 (only for sensor 0)
     *    -1 : thermocouple with AD595
     *     0 : not used
     *     1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
     *     2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
     *     3 : Mendel-parts thermistor (4.7k pullup)
     *     4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
     *     5 : 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
     *     6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
     *     7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
     *    71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
     *     8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
     *     9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
     *    10 : 100k RS thermistor 198-961 (4.7k pullup)
     *    11 : 100k beta 3950 1% thermistor (4.7k pullup)
     *    12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
     *    13 : 100k Hisens 3950  1% up to 300C for hotend "Simple ONE " & "Hotend "All In ONE"
     *    20 : the PT100 circuit found in the Ultimainboard V2.x
     *    60 : 100k Maker's Tool Works Kapton Bed Thermistor beta=3950
     *    66 : 4.7M High Temperature thermistor from Dyze Design
     *    70 : the 100K thermistor found in the bq Hephestos 2
     *    75 : 100k Generic Silicon Heat Pad with NTC 100K MGB18-104F39050L32 thermistor
     *       1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
     *                              (but gives greater accuracy and more stable PID)
     *    51 : 100k thermistor - EPCOS (1k pullup)
     *    52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
     *    55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
     *  1047 : Pt1000 with 4k7 pullup
     *  1010 : Pt1000 with 1k pullup (non standard)
     *   147 : Pt100 with 4k7 pullup
     *   110 : Pt100 with 1k pullup (non standard)
     *         Use these for Testing or Development purposes. NEVER for production machine.
     *   998 : Dummy Table that ALWAYS reads 25C or the temperature defined below.
     *   999 : Dummy Table that ALWAYS reads 100C or the temperature defined below.
     * :{ '0': "Not used", '1':"100k / 4.7k - EPCOS", '2':"200k / 4.7k - ATC Semitec 204GT-2", '3':"Mendel-parts / 4.7k", '4':"10k !! do not use for a hotend. Bad resolution at high temp. !!", '5':"100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '6':"100k / 4.7k EPCOS - Not as accurate as Table 1", '7':"100k / 4.7k Honeywell 135-104LAG-J01", '8':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9':"100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10':"100k / 4.7k RS 198-961", '11':"100k / 4.7k beta 3950 1%", '12':"100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13':"100k Hisens 3950  1% up to 300C for hotend 'Simple ONE ' & hotend 'All In ONE'", '20':"PT100 (Ultimainboard V2.x)", '51':"100k / 1k - EPCOS", '52':"200k / 1k - ATC Semitec 204GT-2", '55':"100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '60':"100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '66':"Dyze Design 4.7M High Temperature thermistor", '70':"the 100K thermistor found in the bq Hephestos 2", '71':"100k / 4.7k Honeywell 135-104LAF-J01", '147':"Pt100 / 4.7k", '1047':"Pt1000 / 4.7k", '110':"Pt100 / 1k (non-standard)", '1010':"Pt1000 / 1k (non standard)", '-3':"Thermocouple + MAX31855 (only for sensor 0)", '-2':"Thermocouple + MAX6675 (only for sensor 0)", '-1':"Thermocouple + AD595",'998':"Dummy 1", '999':"Dummy 2" }
    #define TEMP_SENSOR_0 1
    #define TEMP_SENSOR_1 1
    #define TEMP_SENSOR_2 0
    #define TEMP_SENSOR_3 0
    #define TEMP_SENSOR_4 0
    #define TEMP_SENSOR_BED 1
    // Dummy thermistor constant temperature readings, for use with 998 and 999
    #define DUMMY_THERMISTOR_998_VALUE 25
    #define DUMMY_THERMISTOR_999_VALUE 100
    // Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
    // from the two sensors differ too much the print will be aborted.
    //#define TEMP_SENSOR_1_AS_REDUNDANT
    #define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
    // Extruder temperature must be close to target for this long before M109 returns success
    #define TEMP_RESIDENCY_TIME 10  // (seconds)
    #define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
    #define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
    // Bed temperature must be close to target for this long before M190 returns success
    #define TEMP_BED_RESIDENCY_TIME 10  // (seconds)
    #define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
    #define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
    // The minimal temperature defines the temperature below which the heater will not be enabled It is used
    // to check that the wiring to the thermistor is not broken.
    // Otherwise this would lead to the heater being powered on all the time.
    #define HEATER_0_MINTEMP 5
    #define HEATER_1_MINTEMP 5
    #define HEATER_2_MINTEMP 5
    #define HEATER_3_MINTEMP 5
    #define HEATER_4_MINTEMP 5
    #define BED_MINTEMP 5
    // When temperature exceeds max temp, your heater will be switched off.
    // This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
    // You should use MINTEMP for thermistor short/failure protection.
    #define HEATER_0_MAXTEMP 280
    #define HEATER_1_MAXTEMP 280
    #define HEATER_2_MAXTEMP 275
    #define HEATER_3_MAXTEMP 275
    #define HEATER_4_MAXTEMP 275
    #define BED_MAXTEMP 150
    //============================= PID Settings ================================
    // PID Tuning Guide here: http://reprap.org/wiki/PID_Tuning
    // Comment the following line to disable PID and enable bang-bang.
    #define PIDTEMP
    #define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
    #define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
    #if ENABLED(PIDTEMP)
      //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
      //#define PID_DEBUG // Sends debug data to the serial port.
      //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
      //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
      //#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                      // Set/get with gcode: M301 E[extruder number, 0-2]
      #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
                                      // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
      #define K1 0.95 //smoothing factor within the PID
      // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
      // Ultimaker
      #define  DEFAULT_Kp 22.2
      #define  DEFAULT_Ki 1.08
      #define  DEFAULT_Kd 114
      // MakerGear
      //#define  DEFAULT_Kp 7.0
      //#define  DEFAULT_Ki 0.1
      //#define  DEFAULT_Kd 12
      // Mendel Parts V9 on 12V
      //#define  DEFAULT_Kp 63.0
      //#define  DEFAULT_Ki 2.25
      //#define  DEFAULT_Kd 440
    #endif // PIDTEMP
    //============================= PID > Bed Temperature Control ===============
    // Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
    // Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
    // If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
    // which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
    // This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
    // If your configuration is significantly different than this and you don't understand the issues involved, you probably
    // shouldn't use bed PID until someone else verifies your hardware works.
    // If this is enabled, find your own PID constants below.
    //#define PIDTEMPBED
    //#define BED_LIMIT_SWITCHING
    // This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
    // all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
    // setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
    // so you shouldn't use it unless you are OK with PWM on your bed.  (see the comment on enabling PIDTEMPBED)
    #define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
    #if ENABLED(PIDTEMPBED)
      //#define PID_BED_DEBUG // Sends debug data to the serial port.
      //120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
      //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
      #define  DEFAULT_bedKp 10.00
      #define  DEFAULT_bedKi .023
      #define  DEFAULT_bedKd 305.4
      //from pidautotune
      //#define  DEFAULT_bedKp 97.1
      //#define  DEFAULT_bedKi 1.41
      //#define  DEFAULT_bedKd 1675.16
      // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
    #endif // PIDTEMPBED
    // This option prevents extrusion if the temperature is below EXTRUDE_MINTEMP.
    // It also enables the M302 command to set the minimum extrusion temperature
    // or to allow moving the extruder regardless of the hotend temperature.
    // *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
    #define PREVENT_COLD_EXTRUSION
    #define EXTRUDE_MINTEMP 170
    // This option prevents a single extrusion longer than EXTRUDE_MAXLENGTH.
    // Note that for Bowden Extruders a too-small value here may prevent loading.
    #define PREVENT_LENGTHY_EXTRUDE
    #define EXTRUDE_MAXLENGTH 200
    //======================== Thermal Runaway Protection =======================
     * Thermal Protection protects your printer from damage and fire if a
     * thermistor falls out or temperature sensors fail in any way.
     * The issue: If a thermistor falls out or a temperature sensor fails,
     * Marlin can no longer sense the actual temperature. Since a disconnected
     * thermistor reads as a low temperature, the firmware will keep the heater on.
     * If you get "Thermal Runaway" or "Heating failed" errors the
     * details can be tuned in Configuration_adv.h
    #define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
    #define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
    //============================= Mechanical Settings =========================
    // @section machine
    // Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
    // either in the usual order or reversed
    //#define COREXY
    //#define COREXZ
    //#define COREYZ
    //#define COREYX
    //#define COREZX
    //#define COREZY
    //============================== Endstop Settings ===========================
    // @section homing
    // Specify here all the endstop connectors that are connected to any endstop or probe.
    // Almost all printers will be using one per axis. Probes will use one or more of the
    // extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
    #define USE_XMIN_PLUG
    #define USE_YMIN_PLUG
    #define USE_ZMIN_PLUG
    //#define USE_XMAX_PLUG
    //#define USE_YMAX_PLUG
    //#define USE_ZMAX_PLUG
    // coarse Endstop Settings
    #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
    #if DISABLED(ENDSTOPPULLUPS)
      // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
      //#define ENDSTOPPULLUP_XMAX
      //#define ENDSTOPPULLUP_YMAX
      //#define ENDSTOPPULLUP_ZMAX
      //#define ENDSTOPPULLUP_XMIN
      //#define ENDSTOPPULLUP_YMIN
      //#define ENDSTOPPULLUP_ZMIN
      //#define ENDSTOPPULLUP_ZMIN_PROBE
    #endif
    // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
    #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
    #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
    // Enable this feature if all enabled endstop pins are interrupt-capable.
    // This will remove the need to poll the interrupt pins, saving many CPU cycles.
    //#define ENDSTOP_INTERRUPTS_FEATURE
    //============================== Movement Settings ============================
    // @section motion
     * Default Settings
     * These settings can be reset by M502
     * Note that if EEPROM is enabled, saved values will override these.
     * With this option each E stepper can have its own factors for the
     * following movement settings. If fewer factors are given than the
     * total number of extruders, the last value applies to the rest.
    //#define DISTINCT_E_FACTORS
     * Default Axis Steps Per Unit (steps/mm)
     * Override with M92
     *                                      X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
    #define DEFAULT_AXIS_STEPS_PER_UNIT   { 80, 80, 4000, 615.0 }
     * Default Max Feed Rate (mm/s)
     * Override with M203
    #define DEFAULT_MAX_FEEDRATE          { 250, 250, 2, 22 }
     * Default Max Acceleration (change/s) change = mm/s
     * (Maximum start speed for accelerated moves)
     * Override with M201
    #define DEFAULT_MAX_ACCELERATION      { 1000, 1000, 5, 1000 }
     * Default Acceleration (change/s) change = mm/s
     * Override with M204
     *   M204 P    Acceleration
     *   M204 R    Retract Acceleration
     *   M204 T    Travel Acceleration
    #define DEFAULT_ACCELERATION          500    // X, Y, Z and E acceleration for printing moves
    #define DEFAULT_RETRACT_ACCELERATION  500    // E acceleration for retracts
    #define DEFAULT_TRAVEL_ACCELERATION   1000    // X, Y, Z acceleration for travel (non printing) moves
     * Default Jerk (mm/s)
     * Override with M205 X Y Z E
     * "Jerk" specifies the minimum speed change that requires acceleration.
     * When changing speed and direction, if the difference is less than the
     * value set here, it may happen instantaneously.
    #define DEFAULT_XJERK                 20.0
    #define DEFAULT_YJERK                 20.0
    #define DEFAULT_ZJERK                  0.4
    #define DEFAULT_EJERK                  5.0
    //============================= Z Probe Options =============================
    // @section probes
    // See http://marlinfw.org/configuration/probes.html
     * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
     * Enable this option for a probe connected to the Z Min endstop pin.
    #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
     * Z_MIN_PROBE_ENDSTOP
     * Enable this option for a probe connected to any pin except Z-Min.
     * (By default Marlin assumes the Z-Max endstop pin.)
     * To use a custom Z Probe pin, set Z_MIN_PROBE_PIN below.
     *  - The simplest option is to use a free endstop connector.
     *  - Use 5V for powered (usually inductive) sensors.
     *  - RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
     *    - For simple switches connect...
     *      - normally-closed switches to GND and D32.
     *      - normally-open switches to 5V and D32.
     * WARNING: Setting the wrong pin may have unexpected and potentially
     * disastrous consequences. Use with caution and do your homework.
    //#define Z_MIN_PROBE_ENDSTOP
    //#define Z_MIN_PROBE_PIN Z_MAX_PIN
     * Probe Type
     * Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
     * You must activate one of these to use Auto Bed Leveling below.
     * The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe.
     * Use G29 repeatedly, adjusting the Z height at each point with movement commands
     * or (with LCD_BED_LEVELING) the LCD controller.
    //#define PROBE_MANUALLY
     * A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
     *   (e.g., an inductive probe or a nozzle-based probe-switch.)
    //#define FIX_MOUNTED_PROBE
     * Z Servo Probe, such as an endstop switch on a rotating arm.
    #define Z_ENDSTOP_SERVO_NR 0   // Defaults to SERVO 0 connector.
    #define Z_SERVO_ANGLES {70,0}  // Z Servo Deploy and Stow angles
     * The BLTouch probe uses a Hall effect sensor and emulates a servo.
    //#define BLTOUCH
    #if ENABLED(BLTOUCH)
      //#define BLTOUCH_DELAY 375   // (ms) Enable and increase if needed
    #endif
     * Enable if probing seems unreliable. Heaters and/or fans - consistent with the
     * options selected below - will be disabled during probing so as to minimize
     * potential EM interference by quieting/silencing the source of the 'noise' (the change
     * in current flowing through the wires).  This is likely most useful to users of the
     * BLTouch probe, but may also help those with inductive or other probe types.
    //#define PROBING_HEATERS_OFF       // Turn heaters off when probing
    //#define PROBING_FANS_OFF          // Turn fans off when probing
    // A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
    //#define SOLENOID_PROBE
    // A sled-mounted probe like those designed by Charles Bell.
    //#define Z_PROBE_SLED
    //#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
    // For Z_PROBE_ALLEN_KEY see the Delta example configurations.
     *   Z Probe to nozzle (X,Y) offset, relative to (0, 0).
     *   X and Y offsets must be integers.
     *   In the following example the X and Y offsets are both positive:
     *   #define X_PROBE_OFFSET_FROM_EXTRUDER 10
     *   #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
     *      +-- BACK ---+
     *    L |    (+) P  | R <-- probe (20,20)
     *    E |           | I
     *    F | (-) N (+) | G <-- nozzle (10,10)
     *    T |           | H
     *      |    (-)    | T
     *      O-- FRONT --+
     *    (0,0)
    #define X_PROBE_OFFSET_FROM_EXTRUDER 34  // X offset: -left  +right  [of the nozzle]
    #define Y_PROBE_OFFSET_FROM_EXTRUDER -5  // Y offset: -front +behind [the nozzle]
    #define Z_PROBE_OFFSET_FROM_EXTRUDER -2.00   // Z offset: -below +above  [the nozzle]
    // X and Y axis travel speed (mm/m) between probes
    #define XY_PROBE_SPEED 6000
    // Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
    #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
    // Speed for the "accurate" probe of each point
    #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
    // Use double touch for probing
    //#define PROBE_DOUBLE_TOUCH
     * Z probes require clearance when deploying, stowing, and moving between
     * probe points to avoid hitting the bed and other hardware.
     * Servo-mounted probes require extra space for the arm to rotate.
     * Inductive probes need space to keep from triggering early.
     * Use these settings to specify the distance (mm) to raise the probe (or
     * lower the bed). The values set here apply over and above any (negative)
     * probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
     * Only integer values >= 1 are valid here.
     * Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
     *     But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
    #define Z_CLEARANCE_DEPLOY_PROBE   10 // Z Clearance for Deploy/Stow
    #define Z_CLEARANCE_BETWEEN_PROBES  5 // Z Clearance between probe points
    // For M851 give a range for adjusting the Z probe offset
    #define Z_PROBE_OFFSET_RANGE_MIN -20
    #define Z_PROBE_OFFSET_RANGE_MAX 20
    // Enable the M48 repeatability test to test probe accuracy
    //#define Z_MIN_PROBE_REPEATABILITY_TEST
    // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
    // :{ 0:'Low', 1:'High' }
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define E_ENABLE_ON 0 // For all extruders
    // Disables axis stepper immediately when it's not being used.
    // WARNING: When motors turn off there is a chance of losing position accuracy!
    #define DISABLE_X false
    #define DISABLE_Y false
    #define DISABLE_Z false
    // Warn on display about possibly reduced accuracy
    //#define DISABLE_REDUCED_ACCURACY_WARNING
    #define DISABLE_E false // For all extruders
    #define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
    // @section machine
    // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
    #define INVERT_X_DIR false
    #define INVERT_Y_DIR false
    #define INVERT_Z_DIR true
    // Enable this option for Toshiba stepper drivers
    //#define CONFIG_STEPPERS_TOSHIBA
    // For direct drive extruder v9 set to true, for geared extruder set to false.
    #define INVERT_E0_DIR false
    #define INVERT_E1_DIR false
    #define INVERT_E2_DIR false
    #define INVERT_E3_DIR false
    #define INVERT_E4_DIR false
    // @section homing
    //#define Z_HOMING_HEIGHT 4  // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                                 // Be sure you have this distance over your Z_MAX_POS in case.
    // Direction of endstops when homing; 1=MAX, -1=MIN
    // :[-1,1]
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    // @section machine
    // Travel limits after homing (units are in mm)
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define X_MAX_POS 300
    #define Y_MAX_POS 310
    #define Z_MAX_POS 300
    // If enabled, axes won't move below MIN_POS in response to movement commands.
    #define MIN_SOFTWARE_ENDSTOPS
    // If enabled, axes won't move above MAX_POS in response to movement commands.
    #define MAX_SOFTWARE_ENDSTOPS
     * Filament Runout Sensor
     * A mechanical or opto endstop is used to check for the presence of filament.
     * RAMPS-based boards use SERVO3_PIN.
     * For other boards you may need to define FIL_RUNOUT_PIN.
     * By default the firmware assumes HIGH = has filament, LOW = ran out
    //#define FILAMENT_RUNOUT_SENSOR
    #if ENABLED(FILAMENT_RUNOUT_SENSOR)
      #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
      #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
      #define FILAMENT_RUNOUT_SCRIPT "M600"
    #endif
    //=============================== Bed Leveling ==============================
    // @section bedlevel
     * Choose one of the options below to enable G29 Bed Leveling. The parameters
     * and behavior of G29 will change depending on your selection.
     *  If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
     * - AUTO_BED_LEVELING_3POINT
     *   Probe 3 arbitrary points on the bed (that aren't collinear)
     *   You specify the XY coordinates of all 3 points.
     *   The result is a single tilted plane. Best for a flat bed.
     * - AUTO_BED_LEVELING_LINEAR
     *   Probe several points in a grid.
     *   You specify the rectangle and the density of sample points.
     * - AUTO_BED_LEVELING_BILINEAR
     *   The result is a mesh, best for large or uneven beds.
     * - AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
     *   A comprehensive bed leveling system combining the features and benefits
     *   of other systems. UBL also includes integrated Mesh Generation, Mesh
     *   Validation and Mesh Editing systems. Currently, UBL is only checked out
     *   for Cartesian Printers. That said, it was primarily designed to correct
     *   poor quality Delta Printers. If you feel adventurous and have a Delta,
     *   please post an issue if something doesn't work correctly. Initially,
     *   you will need to set a reduced bed size so you have a rectangular area
     *   to test on.
     * - MESH_BED_LEVELING
     *   Probe a grid manually
     *   The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
     *   For machines without a probe, Mesh Bed Leveling provides a method to perform
     *   leveling in steps so you can manually adjust the Z height at each grid-point.
     *   With an LCD controller the process is guided step-by-step.
    //#define AUTO_BED_LEVELING_3POINT
    //#define AUTO_BED_LEVELING_LINEAR
    //#define AUTO_BED_LEVELING_BILINEAR
    #define AUTO_BED_LEVELING_UBL
    //#define MESH_BED_LEVELING
     * Enable detailed logging of G28, G29, M48, etc.
     * Turn on with the command 'M111 S32'.
     * NOTE: Requires a lot of PROGMEM!
    //#define DEBUG_LEVELING_FEATURE
    #if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL)
      // Gradually reduce leveling correction until a set height is reached,
      // at which point movement will be level to the machine's XY plane.
      // The height can be set with M420 Z<height>
      #define ENABLE_LEVELING_FADE_HEIGHT
    #endif
    #if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
      // Set the number of grid points per dimension.
      #define GRID_MAX_POINTS_X 3
      #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
      // Set the boundaries for probing (where the probe can reach).
      #define LEFT_PROBE_BED_POSITION 15
      #define RIGHT_PROBE_BED_POSITION 170
      #define FRONT_PROBE_BED_POSITION 20
      #define BACK_PROBE_BED_POSITION 170
      // The Z probe minimum outer margin (to validate G29 parameters).
      #define MIN_PROBE_EDGE 10
      // Probe along the Y axis, advancing X after each column
      //#define PROBE_Y_FIRST
      #if ENABLED(AUTO_BED_LEVELING_BILINEAR)
        // Beyond the probed grid, continue the implied tilt?
        // Default is to maintain the height of the nearest edge.
        //#define EXTRAPOLATE_BEYOND_GRID
        // Experimental Subdivision of the grid by Catmull-Rom method.
        // Synthesizes intermediate points to produce a more detailed mesh.
        //#define ABL_BILINEAR_SUBDIVISION
        #if ENABLED(ABL_BILINEAR_SUBDIVISION)
          // Number of subdivisions between probe points
          #define BILINEAR_SUBDIVISIONS 3
        #endif
      #endif
    #elif ENABLED(AUTO_BED_LEVELING_3POINT)
      // 3 arbitrary points to probe.
      // A simple cross-product is used to estimate the plane of the bed.
      #define ABL_PROBE_PT_1_X 15
      #define ABL_PROBE_PT_1_Y 180
      #define ABL_PROBE_PT_2_X 15
      #define ABL_PROBE_PT_2_Y 20
      #define ABL_PROBE_PT_3_X 170
      #define ABL_PROBE_PT_3_Y 20
    #elif ENABLED(AUTO_BED_LEVELING_UBL)
      //========================= Unified Bed Leveling ============================
      #define UBL_MESH_INSET 1          // Mesh inset margin on print area
      #define GRID_MAX_POINTS_X 10      // Don't use more than 15 points per axis, implementation limited.
      #define UBL_PROBE_PT_1_X 39       // These set the probe locations for when UBL does a 3-Point leveling
      #define UBL_PROBE_PT_1_Y 180      // of the mesh.
      #define UBL_PROBE_PT_2_X 39
      #define UBL_PROBE_PT_2_Y 20
      #define UBL_PROBE_PT_3_X 180
      #define UBL_PROBE_PT_3_Y 20
      //#define UBL_G26_MESH_EDITING    // Enable G26 mesh editing
    #elif ENABLED(MESH_BED_LEVELING)
      //=================================== Mesh ==================================
      #define MESH_INSET 10          // Mesh inset margin on print area
      #define GRID_MAX_POINTS_X 3    // Don't use more than 7 points per axis, implementation limited.
      //#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest Z at Z_MIN_POS
    #endif // BED_LEVELING
     * Use the LCD controller for bed leveling
     * Requires MESH_BED_LEVELING or PROBE_MANUALLY
    //#define LCD_BED_LEVELING
    #if ENABLED(LCD_BED_LEVELING)
      #define MBL_Z_STEP 0.025    // Step size while manually probing Z axis.
      #define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS for LCD Z adjustment
    #endif
     * Commands to execute at the end of G29 probing.
     * Useful to retract or move the Z probe out of the way.
    //#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
    // @section homing
    // The center of the bed is at (X=0, Y=0)
    //#define BED_CENTER_AT_0_0
    // Manually set the home position. Leave these undefined for automatic settings.
    // For DELTA this is the top-center of the Cartesian print volume.
    //#define MANUAL_X_HOME_POS 0
    //#define MANUAL_Y_HOME_POS 0
    //#define MANUAL_Z_HOME_POS 0
    // Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
    // With this feature enabled:
    // - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
    // - If stepper drivers time out, it will need X and Y homing again before Z homing.
    // - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
    // - Prevent Z homing when the Z probe is outside bed area.
    #define Z_SAFE_HOMING
    #if ENABLED(Z_SAFE_HOMING)
      #define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2)    // X point for Z homing when homing all axis (G28).
      #define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2)    // Y point for Z homing when homing all axis (G28).
    #endif
    // Homing speeds (mm/m)
    #define HOMING_FEEDRATE_XY (50*60)
    #define HOMING_FEEDRATE_Z  (4*60)
    //============================= Additional Features ===========================
    // @section extras
    // EEPROM
    // The microcontroller can store settings in the EEPROM, e.g. max velocity...
    // M500 - stores parameters in EEPROM
    // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
    // M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
    //define this to enable EEPROM support
    #define EEPROM_SETTINGS
    #if ENABLED(EEPROM_SETTINGS)
      // To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
      #define EEPROM_CHITCHAT // Please keep turned on if you can.
    #endif
    // Host Keepalive
    // When enabled Marlin will send a busy status message to the host
    // every couple of seconds when it can't accept commands.
    #define HOST_KEEPALIVE_FEATURE        // Disable this if your host doesn't like keepalive messages
    #define DEFAULT_KEEPALIVE_INTERVAL 2  // Number of seconds between "busy" messages. Set with M113.
    // M100 Free Memory Watcher
    //#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
    // G20/G21 Inch mode support
    //#define INCH_MODE_SUPPORT
    // M149 Set temperature units support
    //#define TEMPERATURE_UNITS_SUPPORT
    // Preheat Constants
    #define PREHEAT_1_TEMP_HOTEND 195
    #define PREHEAT_1_TEMP_BED     70
    #define PREHEAT_1_FAN_SPEED     255 // Value from 0 to 255
    #define PREHEAT_2_TEMP_HOTEND 225
    #define PREHEAT_2_TEMP_BED    110
    #define PREHEAT_2_FAN_SPEED     255 // Value from 0 to 255
     * Nozzle Park -- EXPERIMENTAL
     * Park the nozzle at the given XYZ position on idle or G27.
     * The "P" parameter controls the action applied to the Z axis:
     *    P0  (Default) If Z is below park Z raise the nozzle.
     *    P1  Raise the nozzle always to Z-park height.
     *    P2  Raise the nozzle by Z-park amount, limited to Z_MAX_POS.
    //#define NOZZLE_PARK_FEATURE
    #if ENABLED(NOZZLE_PARK_FEATURE)
      // Specify a park position as { X, Y, Z }
      #define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
    #endif
     * Clean Nozzle Feature -- EXPERIMENTAL
     * Adds the G12 command to perform a nozzle cleaning process.
     * Parameters:
     *   P  Pattern
     *   S  Strokes / Repetitions
     *   T  Triangles (P1 only)
     * Patterns:
     *   P0  Straight line (default). This process requires a sponge type material
     *       at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
     *       between the start / end points.
     *   P1  Zig-zag pattern between (X0, Y0) and (X1, Y1), "T" specifies the
     *       number of zig-zag triangles to do. "S" defines the number of strokes.
     *       Zig-zags are done in whichever is the narrower dimension.
     *       For example, "G12 P1 S1 T3" will execute:
     *         |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
     *       A |           |   /    \    /    \    /    \   |
     *         |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
     *                       |________|_________|_________|
     *                           T1        T2        T3
     *   P2  Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
     *       "R" specifies the radius. "S" specifies the stroke count.
     *       Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
     *   Caveats: The ending Z should be the same as starting Z.
     * Attention: EXPERIMENTAL. G-code arguments may change.
    //#define NOZZLE_CLEAN_FEATURE
    #if ENABLED(NOZZLE_CLEAN_FEATURE)
      // Default number of pattern repetitions
      #define NOZZLE_CLEAN_STROKES  12
      // Default number of triangles
      #define NOZZLE_CLEAN_TRIANGLES  3
      // Specify positions as { X, Y, Z }
      #define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
      #define NOZZLE_CLEAN_END_POINT   {100, 60, (Z_MIN_POS + 1)}
      // Circular pattern radius
      #define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
      // Circular pattern circle fragments number
      #define NOZZLE_CLEAN_CIRCLE_FN 10
      // Middle point of circle
      #define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
      // Moves the nozzle to the initial position
      #define NOZZLE_CLEAN_GOBACK
    #endif
     * Print Job Timer
     * Automatically start and stop the print job timer on M104/M109/M190.
     *   M104 (hotend, no wait) - high temp = none,        low temp = stop timer
     *   M109 (hotend, wait)    - high temp = start timer, low temp = stop timer
     *   M190 (bed, wait)       - high temp = start timer, low temp = none
     * The timer can also be controlled with the following commands:
     *   M75 - Start the print job timer
     *   M76 - Pause the print job timer
     *   M77 - Stop the print job timer
    #define PRINTJOB_TIMER_AUTOSTART
     * Print Counter
     * Track statistical data such as:
     *  - Total print jobs
     *  - Total successful print jobs
     *  - Total failed print jobs
     *  - Total time printing
     * View the current statistics with M78.
    //#define PRINTCOUNTER
    //============================= LCD and SD support ============================
    // @section lcd
     * LCD LANGUAGE
     * Select the language to display on the LCD. These languages are available:
     *    en, an, bg, ca, cn, cz, de, el, el-gr, es, eu, fi, fr, gl, hr, it,
     *    kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, tr, uk, test
     * :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'tr':'Turkish', 'uk':'Ukrainian', 'test':'TEST' }
    #define LCD_LANGUAGE en
     * LCD Character Set
     * Note: This option is NOT applicable to Graphical Displays.
     * All character-based LCDs provide ASCII plus one of these
     * language extensions:
     *  - JAPANESE ... the most common
     *  - WESTERN  ... with more accented characters
     *  - CYRILLIC ... for the Russian language
     * To determine the language extension installed on your controller:
     *  - Compile and upload with LCD_LANGUAGE set to 'test'
     *  - Click the controller to view the LCD menu
     *  - The LCD will display Japanese, Western, or Cyrillic text
     * See https: *github.com/MarlinFirmware/Marlin/wiki/LCD-Language
     * :['JAPANESE', 'WESTERN', 'CYRILLIC']
    #define DISPLAY_CHARSET_HD44780 JAPANESE
     * LCD TYPE
     * Enable ULTRA_LCD for a 16x2, 16x4, 20x2, or 20x4 character-based LCD.
     * Enable DOGLCD for a 128x64 (ST7565R) Full Graphical Display.
     * (These options will be enabled automatically for most displays.)
     * IMPORTANT: The U8glib library is required for Full Graphic Display!
     *            https://github.com/olikraus/U8glib_Arduino
    //#define ULTRA_LCD   // Character based
    #define DOGLCD      // Full graphics display
     * SD CARD
     * SD Card support is disabled by default. If your controller has an SD slot,
     * you must uncomment the following option or it won't work.
    #define SDSUPPORT
     * SD CARD: SPI SPEED
     * Enable one of the following items for a slower SPI transfer speed.
     * This may be required to resolve "volume init" errors.
    //#define SPI_SPEED SPI_HALF_SPEED
    //#define SPI_SPEED SPI_QUARTER_SPEED
    //#define SPI_SPEED SPI_EIGHTH_SPEED
     * SD CARD: ENABLE CRC
     * Use CRC checks and retries on the SD communication.
    //#define SD_CHECK_AND_RETRY
    // ENCODER SETTINGS
    // This option overrides the default number of encoder pulses needed to
    // produce one step. Should be increased for high-resolution encoders.
    #define ENCODER_PULSES_PER_STEP 2
    // Use this option to override the number of step signals required to
    // move between next/prev menu items.
    #define ENCODER_STEPS_PER_MENU_ITEM 1
     * Encoder Direction Options
     * Test your encoder's behavior first with both options disabled.
     *  Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
     *  Reversed Menu Navigation only?    Enable REVERSE_MENU_DIRECTION.
     *  Reversed Value Editing only?      Enable BOTH options.
    // This option reverses the encoder direction everywhere.
    //  Set this option if CLOCKWISE causes values to DECREASE
    //#define REVERSE_ENCODER_DIRECTION
    // This option reverses the encoder direction for navigating LCD menus.
    //  If CLOCKWISE normally moves DOWN this makes it go UP.
    //  If CLOCKWISE normally moves UP this makes it go DOWN.
    //#define REVERSE_MENU_DIRECTION
    // Individual Axis Homing
    // Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
    //#define INDIVIDUAL_AXIS_HOMING_MENU
    // SPEAKER/BUZZER
    // If you have a speaker that can produce tones, enable it here.
    // By default Marlin assumes you have a buzzer with a fixed frequency.
    //#define SPEAKER
    // The duration and frequency for the UI feedback sound.
    // Set these to 0 to disable audio feedback in the LCD menus.
    // Note: Test audio output with the G-Code:
    //  M300 S<frequency Hz> P<duration ms>
    //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
    //#define LCD_FEEDBACK_FREQUENCY_HZ 1000
    // CONTROLLER TYPE: Standard
    // Marlin supports a wide variety of controllers.
    // Enable one of the following options to specify your controller.
    // ULTIMAKER Controller.
    //#define ULTIMAKERCONTROLLER
    // ULTIPANEL as seen on Thingiverse.
    //#define ULTIPANEL
    // Cartesio UI
    // http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
    //#define CARTESIO_UI
    // PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
    // http://reprap.org/wiki/PanelOne
    //#define PANEL_ONE
    // MaKr3d Makr-Panel with graphic controller and SD support.
    // http://reprap.org/wiki/MaKr3d_MaKrPanel
    //#define MAKRPANEL
    // ReprapWorld Graphical LCD
    // https://reprapworld.com/?products_details&products_id/1218
    //#define REPRAPWORLD_GRAPHICAL_LCD
    // Activate one of these if you have a Panucatt Devices
    // Viki 2.0 or mini Viki with Graphic LCD
    // http://panucatt.com
    //#define VIKI2
    //#define miniVIKI
    // Adafruit ST7565 Full Graphic Controller.
    // https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
    //#define ELB_FULL_GRAPHIC_CONTROLLER
    // RepRapDiscount Smart Controller.
    // http://reprap.org/wiki/RepRapDiscount_Smart_Controller
    // Note: Usually sold with a white PCB.
    //#define REPRAP_DISCOUNT_SMART_CONTROLLER
    // GADGETS3D G3D LCD/SD Controller
    // http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
    // Note: Usually sold with a blue PCB.
    //#define G3D_PANEL
    // RepRapDiscount FULL GRAPHIC Smart Controller
    // http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
    #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
    // MakerLab Mini Panel with graphic
    // controller and SD support - http://reprap.org/wiki/Mini_panel
    //#define MINIPANEL
    // RepRapWorld REPRAPWORLD_KEYPAD v1.1
    // http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
    // REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
    // is pressed, a value of 10.0 means 10mm per click.
    //#define REPRAPWORLD_KEYPAD
    //#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
    // RigidBot Panel V1.0
    // http://www.inventapart.com/
    //#define RIGIDBOT_PANEL
    // BQ LCD Smart Controller shipped by
    // default with the BQ Hephestos 2 and Witbox 2.
    //#define BQ_LCD_SMART_CONTROLLER
    // CONTROLLER TYPE: I2C
    // Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
    // library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
    // Elefu RA Board Control Panel
    // http://www.elefu.com/index.php?route=product/product&product_id=53
    //#define RA_CONTROL_PANEL
    // Sainsmart YW Robot (LCM1602) LCD Display
    //#define LCD_I2C_SAINSMART_YWROBOT
    // Generic LCM1602 LCD adapter
    //#define LCM1602
    // PANELOLU2 LCD with status LEDs,
    // separate encoder and click inputs.
    // Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
    // For more info: https://github.com/lincomatic/LiquidTWI2
    // Note: The PANELOLU2 encoder click input can either be directly connected to
    // a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
    //#define LCD_I2C_PANELOLU2
    // Panucatt VIKI LCD with status LEDs,
    // integrated click & L/R/U/D buttons, separate encoder inputs.
    //#define LCD_I2C_VIKI
    // SSD1306 OLED full graphics generic display
    //#define U8GLIB_SSD1306
    // SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
    //#define SAV_3DGLCD
    #if ENABLED(SAV_3DGLCD)
      #define U8GLIB_SH1106
    #endif
    // CONTROLLER TYPE: Shift register panels
    // 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
    // LCD configuration: http://reprap.org/wiki/SAV_3D_LCD
    //#define SAV_3DLCD
    // TinyBoy2 128x64 OLED / Encoder Panel
    //#define OLED_PANEL_TINYBOY2
    //=============================== Extra Features ==============================
    // @section extras
    // Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
    //#define FAST_PWM_FAN
    // Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
    // which is not as annoying as with the hardware PWM. On the other hand, if this frequency
    // is too low, you should also increment SOFT_PWM_SCALE.
    //#define FAN_SOFT_PWM
    // Incrementing this by 1 will double the software PWM frequency,
    // affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
    // However, control resolution will be halved for each increment;
    // at zero value, there are 128 effective control positions.
    #define SOFT_PWM_SCALE 0
    // If SOFT_PWM_SCALE is set to a value higher than 0, dithering can
    // be used to mitigate the associated resolution loss. If enabled,
    // some of the PWM cycles are stretched so on average the desired
    // duty cycle is attained.
    //#define SOFT_PWM_DITHER
    // Temperature status LEDs that display the hotend and bed temperature.
    // If all hotends, bed temperature, and target temperature are under 54C
    // then the BLUE led is on. Otherwise the RED led is on. (1C hysteresis)
    //#define TEMP_STAT_LEDS
    // M240  Triggers a camera by emulating a Canon RC-1 Remote
    // Data from: http://www.doc-diy.net/photo/rc-1_hacked/
    //#define PHOTOGRAPH_PIN     23
    // SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
    //#define SF_ARC_FIX
    // Support for the BariCUDA Paste Extruder.
    //#define BARICUDA
    //define BlinkM/CyzRgb Support
    //#define BLINKM
     * RGB LED / LED Strip Control
     * Enable support for an RGB LED connected to 5V digital pins, or
     * an RGB Strip connected to MOSFETs controlled by digital pins.
     * Adds the M150 command to set the LED (or LED strip) color.
     * If pins are PWM capable (e.g., 4, 5, 6, 11) then a range of
     * luminance values can be set from 0 to 255.
     * *** CAUTION ***
     *  LED Strips require a MOFSET Chip between PWM lines and LEDs,
     *  as the Arduino cannot handle the current the LEDs will require.
     *  Failure to follow this precaution can destroy your Arduino!
     * *** CAUTION ***
    //#define RGB_LED
    //#define RGBW_LED
    #if ENABLED(RGB_LED) || ENABLED(RGBW_LED)
      #define RGB_LED_R_PIN 34
      #define RGB_LED_G_PIN 43
      #define RGB_LED_B_PIN 35
      #define RGB_LED_W_PIN -1
    #endif
     * Printer Event LEDs
     * During printing, the LEDs will reflect the printer status:
     *  - Gradually change from blue to violet as the heated bed gets to target temp
     *  - Gradually change from violet to red as the hotend gets to temperature
     *  - Change to white to illuminate work surface
     *  - Change to green once print has finished
     *  - Turn off after the print has finished and the user has pushed a button
    #if ENABLED(BLINKM) || ENABLED(RGB_LED) || ENABLED(RGBW_LED)
      #define PRINTER_EVENT_LEDS
    #endif
    * R/C SERVO support
    * Sponsored by TrinityLabs, Reworked by codexmas
    // Number of servos
    // If you select a configuration below, this will receive a default value and does not need to be set manually
    // set it manually if you have more servos than extruders and wish to manually control some
    // leaving it undefined or defining as 0 will disable the servo subsystem
    // If unsure, leave commented / disabled
    #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command
    // Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle.
    // 300ms is a good value but you can try less delay.
    // If the servo can't reach the requested position, increase it.
    #define SERVO_DELAY 300
    // Servo deactivation
    // With this option servos are powered only during movement, then turned off to prevent jitter.
    //#define DEACTIVATE_SERVOS_AFTER_MOVE
     * Filament Width Sensor
     * Measures the filament width in real-time and adjusts
     * flow rate to compensate for any irregularities.
     * Also allows the measured filament diameter to set the
     * extrusion rate, so the slicer only has to specify the
     * volume.
     * Only a single extruder is supported at this time.
     *  34 RAMPS_14    : Analog input 5 on the AUX2 connector
     *  81 PRINTRBOARD : Analog input 2 on the Exp1 connector (version B,C,D,E)
     * 301 RAMBO       : Analog input 3
     * Note: May require analog pins to be defined for other boards.
    //#define FILAMENT_WIDTH_SENSOR
    #define DEFAULT_NOMINAL_FILAMENT_DIA 3.00   // (mm) Diameter of the filament generally used (3.0 or 1.75mm), also used in the slicer. Used to validate sensor reading.
    #if ENABLED(FILAMENT_WIDTH_SENSOR)
      #define FILAMENT_SENSOR_EXTRUDER_NUM 0    // Index of the extruder that has the filament sensor (0,1,2,3)
      #define MEASUREMENT_DELAY_CM        14    // (cm) The distance from the filament sensor to the melting chamber
      #define MEASURED_UPPER_LIMIT         3.30 // (mm) Upper limit used to validate sensor reading
      #define MEASURED_LOWER_LIMIT         1.90 // (mm) Lower limit used to validate sensor reading
      #define MAX_MEASUREMENT_DELAY       20    // (bytes) Buffer size for stored measurements (1 byte per cm). Must be larger than MEASUREMENT_DELAY_CM.
      #define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA // Set measured to nominal initially
      // Display filament width on the LCD status line. Status messages will expire after 5 seconds.
      //#define FILAMENT_LCD_DISPLAY
    #endif
    #endif // CONFIGURATION_H
  3. #3
    Configuration_adv.h
    Code:
     * Copyright (C) 2016 MarlinFirmware [https://github.com/MarlinFirmware/Marlin]
     * Based on Sprinter and grbl.
     * Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
     * This program is free software: you can redistribute it and/or modify
     * it under the terms of the GNU General Public License as published by
     * the Free Software Foundation, either version 3 of the License, or
     * (at your option) any later version.
     * This program is distributed in the hope that it will be useful,
     * but WITHOUT ANY WARRANTY; without even the implied warranty of
     * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
     * GNU General Public License for more details.
     * You should have received a copy of the GNU General Public License
     * along with this program.  If not, see <http://www.gnu.org/licenses/>.
     * Configuration_adv.h
     * Advanced settings.
     * Only change these if you know exactly what you're doing.
     * Some of these settings can damage your printer if improperly set!
     * Basic settings can be found in Configuration.h
    #ifndef CONFIGURATION_ADV_H
    #define CONFIGURATION_ADV_H
    #define CONFIGURATION_ADV_H_VERSION 010100
    //=============================Thermal Settings  ============================
    #if DISABLED(PIDTEMPBED)
      #define BED_CHECK_INTERVAL 5000 // ms between checks in bang-bang control
      #if ENABLED(BED_LIMIT_SWITCHING)
        #define BED_HYSTERESIS 2 // Only disable heating if T>target+BED_HYSTERESIS and enable heating if T>target-BED_HYSTERESIS
      #endif
    #endif
     * The solution: Once the temperature reaches the target, start observing.
     * If the temperature stays too far below the target (hysteresis) for too long (period),
     * the firmware will halt the machine as a safety precaution.
     * If you get false positives for "Thermal Runaway" increase THERMAL_PROTECTION_HYSTERESIS and/or THERMAL_PROTECTION_PERIOD
    #if ENABLED(THERMAL_PROTECTION_HOTENDS)
      #define THERMAL_PROTECTION_PERIOD 40        // Seconds
      #define THERMAL_PROTECTION_HYSTERESIS 4     // Degrees Celsius
       * Whenever an M104 or M109 increases the target temperature the firmware will wait for the
       * WATCH_TEMP_PERIOD to expire, and if the temperature hasn't increased by WATCH_TEMP_INCREASE
       * degrees, the machine is halted, requiring a hard reset. This test restarts with any M104/M109,
       * but only if the current temperature is far enough below the target for a reliable test.
       * If you get false positives for "Heating failed" increase WATCH_TEMP_PERIOD and/or decrease WATCH_TEMP_INCREASE
       * WATCH_TEMP_INCREASE should not be below 2.
      #define WATCH_TEMP_PERIOD 20                // Seconds
      #define WATCH_TEMP_INCREASE 2               // Degrees Celsius
    #endif
     * Thermal Protection parameters for the bed are just as above for hotends.
    #if ENABLED(THERMAL_PROTECTION_BED)
      #define THERMAL_PROTECTION_BED_PERIOD 20    // Seconds
      #define THERMAL_PROTECTION_BED_HYSTERESIS 2 // Degrees Celsius
       * Whenever an M140 or M190 increases the target temperature the firmware will wait for the
       * WATCH_BED_TEMP_PERIOD to expire, and if the temperature hasn't increased by WATCH_BED_TEMP_INCREASE
       * degrees, the machine is halted, requiring a hard reset. This test restarts with any M140/M190,
       * If you get too many "Heating failed" errors, increase WATCH_BED_TEMP_PERIOD and/or decrease
       * WATCH_BED_TEMP_INCREASE. (WATCH_BED_TEMP_INCREASE should not be below 2.)
      #define WATCH_BED_TEMP_PERIOD 60                // Seconds
      #define WATCH_BED_TEMP_INCREASE 2               // Degrees Celsius
    #endif
      // this adds an experimental additional term to the heating power, proportional to the extrusion speed.
      // if Kc is chosen well, the additional required power due to increased melting should be compensated.
      //#define PID_EXTRUSION_SCALING
      #if ENABLED(PID_EXTRUSION_SCALING)
        #define DEFAULT_Kc (100) //heating power=Kc*(e_speed)
        #define LPQ_MAX_LEN 50
      #endif
    #endif
     * Automatic Temperature:
     * The hotend target temperature is calculated by all the buffered lines of gcode.
     * The maximum buffered steps/sec of the extruder motor is called "se".
     * Start autotemp mode with M109 S<mintemp> B<maxtemp> F<factor>
     * The target temperature is set to mintemp+factor*se[steps/sec] and is limited by
     * mintemp and maxtemp. Turn this off by executing M109 without F*
     * Also, if the temperature is set to a value below mintemp, it will not be changed by autotemp.
     * On an Ultimaker, some initial testing worked with M109 S215 B260 F1 in the start.gcode
    #define AUTOTEMP
    #if ENABLED(AUTOTEMP)
      #define AUTOTEMP_OLDWEIGHT 0.98
    #endif
    //Show Temperature ADC value
    //The M105 command return, besides traditional information, the ADC value read from temperature sensors.
    //#define SHOW_TEMP_ADC_VALUES
     * High Temperature Thermistor Support
     * Thermistors able to support high temperature tend to have a hard time getting
     * good readings at room and lower temperatures. This means HEATER_X_RAW_LO_TEMP
     * will probably be caught when the heating element first turns on during the
     * preheating process, which will trigger a min_temp_error as a safety measure
     * and force stop everything.
     * To circumvent this limitation, we allow for a preheat time (during which,
     * min_temp_error won't be triggered) and add a min_temp buffer to handle
     * aberrant readings.
     * If you want to enable this feature for your hotend thermistor(s)
     * uncomment and set values > 0 in the constants below
    // The number of consecutive low temperature errors that can occur
    // before a min_temp_error is triggered. (Shouldn't be more than 10.)
    //#define MAX_CONSECUTIVE_LOW_TEMPERATURE_ERROR_ALLOWED 0
    // The number of milliseconds a hotend will preheat before starting to check
    // the temperature. This value should NOT be set to the time it takes the
    // hot end to reach the target temperature, but the time it takes to reach
    // the minimum temperature your thermistor can read. The lower the better/safer.
    // This shouldn't need to be more than 30 seconds (30000)
    //#define MILLISECONDS_PREHEAT_TIME 0
    // Extruder runout prevention.
    // If the machine is idle and the temperature over MINTEMP
    // then extrude some filament every couple of SECONDS.
    //#define EXTRUDER_RUNOUT_PREVENT
    #if ENABLED(EXTRUDER_RUNOUT_PREVENT)
      #define EXTRUDER_RUNOUT_MINTEMP 190
      #define EXTRUDER_RUNOUT_SECONDS 30
      #define EXTRUDER_RUNOUT_SPEED 1500  // mm/m
      #define EXTRUDER_RUNOUT_EXTRUDE 5   // mm
    #endif
    //These defines help to calibrate the AD595 sensor in case you get wrong temperature measurements.
    //The measured temperature is defined as "actualTemp = (measuredTemp * TEMP_SENSOR_AD595_GAIN) + TEMP_SENSOR_AD595_OFFSET"
    #define TEMP_SENSOR_AD595_OFFSET 0.0
    #define TEMP_SENSOR_AD595_GAIN   1.0
     * Controller Fan
     * To cool down the stepper drivers and MOSFETs.
     * The fan will turn on automatically whenever any stepper is enabled
     * and turn off after a set period after all steppers are turned off.
    //#define USE_CONTROLLER_FAN
    #if ENABLED(USE_CONTROLLER_FAN)
      //#define CONTROLLER_FAN_PIN FAN1_PIN  // Set a custom pin for the controller fan
      #define CONTROLLERFAN_SECS 60          // Duration in seconds for the fan to run after all motors are disabled
      #define CONTROLLERFAN_SPEED 255        // 255 == full speed
    #endif
    // When first starting the main fan, run it at full speed for the
    // given number of milliseconds.  This gets the fan spinning reliably
    // before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu)
    //#define FAN_KICKSTART_TIME 100
    // This defines the minimal speed for the main fan, run in PWM mode
    // to enable uncomment and set minimal PWM speed for reliable running (1-255)
    // if fan speed is [1 - (FAN_MIN_PWM-1)] it is set to FAN_MIN_PWM
    //#define FAN_MIN_PWM 50
     * Extruder cooling fans
     * Extruder auto fans automatically turn on when their extruders'
     * temperatures go above EXTRUDER_AUTO_FAN_TEMPERATURE.
     * Your board's pins file specifies the recommended pins. Override those here
     * or set to -1 to disable completely.
     * Multiple extruders can be assigned to the same pin in which case
     * the fan will turn on when any selected extruder is above the threshold.
    #define E0_AUTO_FAN_PIN -1
    #define E1_AUTO_FAN_PIN -1
    #define E2_AUTO_FAN_PIN -1
    #define E3_AUTO_FAN_PIN -1
    #define E4_AUTO_FAN_PIN -1
    #define EXTRUDER_AUTO_FAN_TEMPERATURE 50
    #define EXTRUDER_AUTO_FAN_SPEED   255  // == full speed
    // Define a pin to turn case light on/off
    //#define CASE_LIGHT_PIN 4
    #if PIN_EXISTS(CASE_LIGHT)
      #define INVERT_CASE_LIGHT false   // Set to true if HIGH is the OFF state (active low)
      //#define CASE_LIGHT_DEFAULT_ON   // Uncomment to set default state to on
      //#define MENU_ITEM_CASE_LIGHT    // Uncomment to have a Case Light On / Off entry in main menu
    #endif
    //============================ Mechanical Settings ==========================
    // @section homing
    // If you want endstops to stay on (by default) even when not homing
    // enable this option. Override at any time with M120, M121.
    //#define ENDSTOPS_ALWAYS_ON_DEFAULT
    // @section extras
    //#define Z_LATE_ENABLE // Enable Z the last moment. Needed if your Z driver overheats.
    // Dual X Steppers
    // Uncomment this option to drive two X axis motors.
    // The next unused E driver will be assigned to the second X stepper.
    //#define X_DUAL_STEPPER_DRIVERS
    #if ENABLED(X_DUAL_STEPPER_DRIVERS)
      // Set true if the two X motors need to rotate in opposite directions
      #define INVERT_X2_VS_X_DIR true
    #endif
    // Dual Y Steppers
    // Uncomment this option to drive two Y axis motors.
    // The next unused E driver will be assigned to the second Y stepper.
    //#define Y_DUAL_STEPPER_DRIVERS
    #if ENABLED(Y_DUAL_STEPPER_DRIVERS)
      // Set true if the two Y motors need to rotate in opposite directions
      #define INVERT_Y2_VS_Y_DIR true
    #endif
    // A single Z stepper driver is usually used to drive 2 stepper motors.
    // Uncomment this option to use a separate stepper driver for each Z axis motor.
    // The next unused E driver will be assigned to the second Z stepper.
    //#define Z_DUAL_STEPPER_DRIVERS
    #if ENABLED(Z_DUAL_STEPPER_DRIVERS)
      // Z_DUAL_ENDSTOPS is a feature to enable the use of 2 endstops for both Z steppers - Let's call them Z stepper and Z2 stepper.
      // That way the machine is capable to align the bed during home, since both Z steppers are homed.
      // There is also an implementation of M666 (software endstops adjustment) to this feature.
      // After Z homing, this adjustment is applied to just one of the steppers in order to align the bed.
      // One just need to home the Z axis and measure the distance difference between both Z axis and apply the math: Z adjust = Z - Z2.
      // If the Z stepper axis is closer to the bed, the measure Z > Z2 (yes, it is.. think about it) and the Z adjust would be positive.
      // Play a little bit with small adjustments (0.5mm) and check the behaviour.
      // The M119 (endstops report) will start reporting the Z2 Endstop as well.
      //#define Z_DUAL_ENDSTOPS
      #if ENABLED(Z_DUAL_ENDSTOPS)
        #define Z2_USE_ENDSTOP _XMAX_
        #define Z_DUAL_ENDSTOPS_ADJUSTMENT  0  // use M666 command to determine/test this value
      #endif
    #endif // Z_DUAL_STEPPER_DRIVERS
    // Enable this for dual x-carriage printers.
    // A dual x-carriage design has the advantage that the inactive extruder can be parked which
    // prevents hot-end ooze contaminating the print. It also reduces the weight of each x-carriage
    // allowing faster printing speeds. Connect your X2 stepper to the first unused E plug.
    //#define DUAL_X_CARRIAGE
    #if ENABLED(DUAL_X_CARRIAGE)
      // Configuration for second X-carriage
      // Note: the first x-carriage is defined as the x-carriage which homes to the minimum endstop;
      // the second x-carriage always homes to the maximum endstop.
      #define X2_MIN_POS 80     // set minimum to ensure second x-carriage doesn't hit the parked first X-carriage
      #define X2_MAX_POS 353    // set maximum to the distance between toolheads when both heads are homed
      #define X2_HOME_DIR 1     // the second X-carriage always homes to the maximum endstop position
      #define X2_HOME_POS X2_MAX_POS // default home position is the maximum carriage position
          // However: In this mode the HOTEND_OFFSET_X value for the second extruder provides a software
          // override for X2_HOME_POS. This also allow recalibration of the distance between the two endstops
          // without modifying the firmware (through the "M218 T1 X???" command).
          // Remember: you should set the second extruder x-offset to 0 in your slicer.
      // There are a few selectable movement modes for dual x-carriages using M605 S<mode>
      //    Mode 0 (DXC_FULL_CONTROL_MODE): Full control. The slicer has full control over both x-carriages and can achieve optimal travel results
      //                                    as long as it supports dual x-carriages. (M605 S0)
      //    Mode 1 (DXC_AUTO_PARK_MODE)   : Auto-park mode. The firmware will automatically park and unpark the x-carriages on tool changes so
      //                                    that additional slicer support is not required. (M605 S1)
      //    Mode 2 (DXC_DUPLICATION_MODE) : Duplication mode. The firmware will transparently make the second x-carriage and extruder copy all
      //                                    actions of the first x-carriage. This allows the printer to print 2 arbitrary items at
      //                                    once. (2nd extruder x offset and temp offset are set using: M605 S2 [Xnnn] [Rmmm])
      // This is the default power-up mode which can be later using M605.
      #define DEFAULT_DUAL_X_CARRIAGE_MODE DXC_FULL_CONTROL_MODE
      // Default settings in "Auto-park Mode"
      #define TOOLCHANGE_PARK_ZLIFT   0.2      // the distance to raise Z axis when parking an extruder
      #define TOOLCHANGE_UNPARK_ZLIFT 1        // the distance to raise Z axis when unparking an extruder
      // Default x offset in duplication mode (typically set to half print bed width)
      #define DEFAULT_DUPLICATION_X_OFFSET 100
    #endif // DUAL_X_CARRIAGE
    // Activate a solenoid on the active extruder with M380. Disable all with M381.
    // Define SOL0_PIN, SOL1_PIN, etc., for each extruder that has a solenoid.
    //#define EXT_SOLENOID
    // @section homing
    //homing hits the endstop, then retracts by this distance, before it tries to slowly bump again:
    #define X_HOME_BUMP_MM 5
    #define Y_HOME_BUMP_MM 5
    #define Z_HOME_BUMP_MM 2
    #define HOMING_BUMP_DIVISOR {2, 2, 4}  // Re-Bump Speed Divisor (Divides the Homing Feedrate)
    //#define QUICK_HOME  //if this is defined, if both x and y are to be homed, a diagonal move will be performed initially.
    // When G28 is called, this option will make Y home before X
    //#define HOME_Y_BEFORE_X
    // @section machine
    #define AXIS_RELATIVE_MODES {false, false, false, false}
    // Allow duplication mode with a basic dual-nozzle extruder
    //#define DUAL_NOZZLE_DUPLICATION_MODE
    // By default pololu step drivers require an active high signal. However, some high power drivers require an active low signal as step.
    #define INVERT_X_STEP_PIN false
    #define INVERT_Y_STEP_PIN false
    #define INVERT_Z_STEP_PIN false
    #define INVERT_E_STEP_PIN false
    // Default stepper release if idle. Set to 0 to deactivate.
    // Steppers will shut down DEFAULT_STEPPER_DEACTIVE_TIME seconds after the last move when DISABLE_INACTIVE_? is true.
    // Time can be set by M18 and M84.
    #define DEFAULT_STEPPER_DEACTIVE_TIME 120
    #define DISABLE_INACTIVE_X true
    #define DISABLE_INACTIVE_Y true
    #define DISABLE_INACTIVE_Z true  // set to false if the nozzle will fall down on your printed part when print has finished.
    #define DISABLE_INACTIVE_E true
    #define DEFAULT_MINIMUMFEEDRATE       0.0     // minimum feedrate
    #define DEFAULT_MINTRAVELFEEDRATE     0.0
    // @section lcd
    #if ENABLED(ULTIPANEL)
      #define MANUAL_FEEDRATE {50*60, 50*60, 4*60, 60} // Feedrates for manual moves along X, Y, Z, E from panel
      #define ULTIPANEL_FEEDMULTIPLY  // Comment to disable setting feedrate multiplier via encoder
    #endif
    // @section extras
    // minimum time in microseconds that a movement needs to take if the buffer is emptied.
    #define DEFAULT_MINSEGMENTTIME        20000
    // If defined the movements slow down when the look ahead buffer is only half full
    #define SLOWDOWN
    // Frequency limit
    // See nophead's blog for more info
    // Not working O
    //#define XY_FREQUENCY_LIMIT  15
    // Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end
    // of the buffer and all stops. This should not be much greater than zero and should only be changed
    // if unwanted behavior is observed on a user's machine when running at very slow speeds.
    #define MINIMUM_PLANNER_SPEED 0.05// (mm/sec)
    // Microstep setting (Only functional when stepper driver microstep pins are connected to MCU.
    #define MICROSTEP_MODES {16,16,16,16,16} // [1,2,4,8,16]
     *  @section  stepper motor current
     *  Some boards have a means of setting the stepper motor current via firmware.
     *  The power on motor currents are set by:
     *    PWM_MOTOR_CURRENT - used by MINIRAMBO & ULTIMAIN_2
     *                         known compatible chips: A4982
     *    DIGIPOT_MOTOR_CURRENT - used by BQ_ZUM_MEGA_3D, RAMBO & SCOOVO_X9H
     *                         known compatible chips: AD5206
     *    DAC_MOTOR_CURRENT_DEFAULT - used by PRINTRBOARD_REVF & RIGIDBOARD_V2
     *                         known compatible chips: MCP4728
     *    DIGIPOT_I2C_MOTOR_CURRENTS - used by 5DPRINT, AZTEEG_X3_PRO, MIGHTYBOARD_REVE
     *                         known compatible chips: MCP4451, MCP4018
     *  Motor currents can also be set by M907 - M910 and by the LCD.
     *    M907 - applies to all.
     *    M908 - BQ_ZUM_MEGA_3D, RAMBO, PRINTRBOARD_REVF, RIGIDBOARD_V2 & SCOOVO_X9H
     *    M909, M910 & LCD - only PRINTRBOARD_REVF & RIGIDBOARD_V2
    //#define PWM_MOTOR_CURRENT {1300, 1300, 1250} // Values in milliamps
    #define DIGIPOT_MOTOR_CURRENT {135,135,135,135,135} // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
    //#define DAC_MOTOR_CURRENT_DEFAULT { 70, 80, 90, 80 } // Default drive percent - X, Y, Z, E axis
    // Uncomment to enable an I2C based DIGIPOT like on the Azteeg X3 Pro
    //#define DIGIPOT_I2C
    //#define DIGIPOT_MCP4018
    #define DIGIPOT_I2C_NUM_CHANNELS 8 // 5DPRINT: 4     AZTEEG_X3_PRO: 8
    // Actual motor currents in Amps, need as many here as DIGIPOT_I2C_NUM_CHANNELS
    #define DIGIPOT_I2C_MOTOR_CURRENTS {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}  //  AZTEEG_X3_PRO
    //=============================Additional Features===========================
    #define ENCODER_RATE_MULTIPLIER         // If defined, certain menu edit operations automatically multiply the steps when the encoder is moved quickly
    #define ENCODER_10X_STEPS_PER_SEC 75    // If the encoder steps per sec exceeds this value, multiply steps moved x10 to quickly advance the value
    #define ENCODER_100X_STEPS_PER_SEC 160  // If the encoder steps per sec exceeds this value, multiply steps moved x100 to really quickly advance the value
    //#define CHDK 4        //Pin for triggering CHDK to take a picture see how to use it here http://captain-slow.dk/2014/03/09/3d-printing-timelapses/
    #define CHDK_DELAY 50 //How long in ms the pin should stay HIGH before going LOW again
    // @section lcd
    // Include a page of printer information in the LCD Main Menu
    #define LCD_INFO_MENU
    // On the Info Screen, display XY with one decimal place when possible
    //#define LCD_DECIMAL_SMALL_XY
    // The timeout (in ms) to return to the status screen from sub-menus
    //#define LCD_TIMEOUT_TO_STATUS 15000
    #if ENABLED(SDSUPPORT)
      // Some RAMPS and other boards don't detect when an SD card is inserted. You can work
      // around this by connecting a push button or single throw switch to the pin defined
      // as SD_DETECT_PIN in your board's pins definitions.
      // This setting should be disabled unless you are using a push button, pulling the pin to ground.
      // Note: This is always disabled for ULTIPANEL (except ELB_FULL_GRAPHIC_CONTROLLER).
      #define SD_DETECT_INVERTED
      #define SD_FINISHED_STEPPERRELEASE true  //if sd support and the file is finished: disable steppers?
      #define SD_FINISHED_RELEASECOMMAND "M84 X Y Z E" // You might want to keep the z enabled so your bed stays in place.
      #define SDCARD_RATHERRECENTFIRST  //reverse file order of sd card menu display. Its sorted practically after the file system block order.
      // if a file is deleted, it frees a block. hence, the order is not purely chronological. To still have auto0.g accessible, there is again the option to do that.
      // using:
      //#define MENU_ADDAUTOSTART
       * Sort SD file listings in alphabetical order.
       * With this option enabled, items on SD cards will be sorted
       * by name for easier navigation.
       * By default...
       *  - Use the slowest -but safest- method for sorting.
       *  - Folders are sorted to the top.
       *  - The sort key is statically allocated.
       *  - No added G-code (M34) support.
       *  - 40 item sorting limit. (Items after the first 40 are unsorted.)
       * SD sorting uses static allocation (as set by SDSORT_LIMIT), allowing the
       * compiler to calculate the worst-case usage and throw an error if the SRAM
       * limit is exceeded.
       *  - SDSORT_USES_RAM provides faster sorting via a static directory buffer.
       *  - SDSORT_USES_STACK does the same, but uses a local stack-based buffer.
       *  - SDSORT_CACHE_NAMES will retain the sorted file listing in RAM. (Expensive!)
       *  - SDSORT_DYNAMIC_RAM only uses RAM when the SD menu is visible. (Use with caution!)
    #define SDCARD_SORT_ALPHA
      // SD Card Sorting options
      #if ENABLED(SDCARD_SORT_ALPHA)
        #define SDSORT_LIMIT       40     // Maximum number of sorted items (10-256).
        #define FOLDER_SORTING     -1     // -1=above  0=none  1=below
        #define SDSORT_GCODE       false  // Allow turning sorting on/off with LCD and M34 g-code.
        #define SDSORT_USES_RAM    false  // Pre-allocate a static array for faster pre-sorting.
        #define SDSORT_USES_STACK  false  // Prefer the stack for pre-sorting to give back some SRAM. (Negated by next 2 options.)
        #define SDSORT_CACHE_NAMES false  // Keep sorted items in RAM longer for speedy performance. Most expensive option.
        #define SDSORT_DYNAMIC_RAM false  // Use dynamic allocation (within SD menus). Least expensive option. Set SDSORT_LIMIT before use!
      #endif
      // Show a progress bar on HD44780 LCDs for SD printing
      //#define LCD_PROGRESS_BAR
      #if ENABLED(LCD_PROGRESS_BAR)
        // Amount of time (ms) to show the bar
        #define PROGRESS_BAR_BAR_TIME 2000
        // Amount of time (ms) to show the status message
        #define PROGRESS_BAR_MSG_TIME 3000
        // Amount of time (ms) to retain the status message (0=forever)
        #define PROGRESS_MSG_EXPIRE   0
        // Enable this to show messages for MSG_TIME then hide them
        //#define PROGRESS_MSG_ONCE
        // Add a menu item to test the progress bar:
        //#define LCD_PROGRESS_BAR_TEST
      #endif
      // This allows hosts to request long names for files and folders with M33
      #define LONG_FILENAME_HOST_SUPPORT
      // This option allows you to abort SD printing when any endstop is triggered.
      // This feature must be enabled with "M540 S1" or from the LCD menu.
      // To have any effect, endstops must be enabled during SD printing.
      //#define ABORT_ON_ENDSTOP_HIT_FEATURE_ENABLED
    #endif // SDSUPPORT
     * Additional options for Graphical Displays
     * Use the optimizations here to improve printing performance,
     * which can be adversely affected by graphical display drawing,
     * especially when doing several short moves, and when printing
     * on DELTA and SCARA machines.
     * Some of these options may result in the display lagging behind
     * controller events, as there is a trade-off between reliable
     * printing performance versus fast display updates.
    #if ENABLED(DOGLCD)
      // Enable to save many cycles by drawing a hollow frame on the Info Screen
      #define XYZ_HOLLOW_FRAME
      // Enable to save many cycles by drawing a hollow frame on Menu Screens
      #define MENU_HOLLOW_FRAME
      // A bigger font is available for edit items. Costs 3120 bytes of PROGMEM.
      // Western only. Not available for Cyrillic, Kana, Turkish, Greek, or Chinese.
      //#define USE_BIG_EDIT_FONT
      // A smaller font may be used on the Info Screen. Costs 2300 bytes of PROGMEM.
      //#define USE_SMALL_INFOFONT
      // Enable this option and reduce the value to optimize screen updates.
      // The normal delay is 10s. Use the lowest value that still gives a reliable display.
      //#define DOGM_SPI_DELAY_US 5
    #endif // DOGLCD
    // @section safety
    // The hardware watchdog should reset the microcontroller disabling all outputs,
    // in case the firmware gets stuck and doesn't do temperature regulation.
    //#define USE_WATCHDOG
    #if ENABLED(USE_WATCHDOG)
      // If you have a watchdog reboot in an ArduinoMega2560 then the device will hang forever, as a watchdog reset will leave the watchdog on.
      // The "WATCHDOG_RESET_MANUAL" goes around this by not using the hardware reset.
      //  However, THIS FEATURE IS UNSAFE!, as it will only work if interrupts are disabled. And the code could hang in an interrupt routine with interrupts disabled.
      //#define WATCHDOG_RESET_MANUAL
    #endif
    // @section lcd
     * Babystepping enables movement of the axes by tiny increments without changing
     * the current position values. This feature is used primarily to adjust the Z
     * axis in the first layer of a print in real-time.
     * Warning: Does not respect endstops!
    #define BABYSTEPPING
    #if ENABLED(BABYSTEPPING)
      #define BABYSTEP_XY              // Also enable X/Y Babystepping. Not supported on DELTA!
      #define BABYSTEP_INVERT_Z false  // Change if Z babysteps should go the other way
      #define BABYSTEP_MULTIPLICATOR 1 // Babysteps are very small. Increase for faster motion.
      //#define BABYSTEP_ZPROBE_OFFSET // Enable to combine M851 and Babystepping
      #define DOUBLECLICK_FOR_Z_BABYSTEPPING // Double-click on the Status Screen for Z Babystepping.
      #define DOUBLECLICK_MAX_INTERVAL 1250 // Maximum interval between clicks, in milliseconds.
                                            // Note: Extra time may be added to mitigate controller latency.
    #endif
    // @section extruder
    // extruder advance constant (s2/mm3)
    // advance (steps) = STEPS_PER_CUBIC_MM_E * EXTRUDER_ADVANCE_K * cubic mm per second ^ 2
    // Hooke's law says:    force = k * distance
    // Bernoulli's principle says:  v ^ 2 / 2 + g . h + pressure / density = constant
    // so: v ^ 2 is proportional to number of steps we advance the extruder
    //#define ADVANCE
    #if ENABLED(ADVANCE)
      #define EXTRUDER_ADVANCE_K .0
      #define D_FILAMENT 2.85
    #endif
     * Implementation of linear pressure control
     * Assumption: advance = k * (delta velocity)
     * K=0 means advance disabled.
     * See Marlin documentation for calibration instructions.
    //#define LIN_ADVANCE
    #if ENABLED(LIN_ADVANCE)
      #define LIN_ADVANCE_K 75
       * Some Slicers produce Gcode with randomly jumping extrusion widths occasionally.
       * For example within a 0.4mm perimeter it may produce a single segment of 0.05mm width.
       * While this is harmless for normal printing (the fluid nature of the filament will
       * close this very, very tiny gap), it throws off the LIN_ADVANCE pressure adaption.
       * For this case LIN_ADVANCE_E_D_RATIO can be used to set the extrusion:distance ratio
       * to a fixed value. Note that using a fixed ratio will lead to wrong nozzle pressures
       * if the slicer is using variable widths or layer heights within one print!
       * This option sets the default E:D ratio at startup. Use `M900` to override this value.
       * Example: `M900 W0.4 H0.2 D1.75`, where:
       *   - W is the extrusion width in mm
       *   - H is the layer height in mm
       *   - D is the filament diameter in mm
       * Example: `M900 R0.0458` to set the ratio directly.
       * Set to 0 to auto-detect the ratio based on given Gcode G1 print moves.
       * Slic3r (including Prusa Slic3r) produces Gcode compatible with the automatic mode.
       * Cura (as of this writing) may produce Gcode incompatible with the automatic mode.
      #define LIN_ADVANCE_E_D_RATIO 0 // The calculated ratio (or 0) according to the formula W * H / ((D / 2) ^ 2 * PI)
                                      // Example: 0.4 * 0.2 / ((1.75 / 2) ^ 2 * PI) = 0.033260135
    #endif
    // @section leveling
    // Default mesh area is an area with an inset margin on the print area.
    // Below are the macros that are used to define the borders for the mesh area,
    // made available here for specialized needs, ie dual extruder setup.
      #define MESH_MIN_X (X_MIN_POS + MESH_INSET)
      #define MESH_MAX_X (X_MAX_POS - (MESH_INSET))
      #define MESH_MIN_Y (Y_MIN_POS + MESH_INSET)
      #define MESH_MAX_Y (Y_MAX_POS - (MESH_INSET))
      #define UBL_MESH_MIN_X (X_MIN_POS + UBL_MESH_INSET)
      #define UBL_MESH_MAX_X (X_MAX_POS - (UBL_MESH_INSET))
      #define UBL_MESH_MIN_Y (Y_MIN_POS + UBL_MESH_INSET)
      #define UBL_MESH_MAX_Y (Y_MAX_POS - (UBL_MESH_INSET))
      // If this is defined, the currently active mesh will be saved in the
      // current slot on M500.
      #define UBL_SAVE_ACTIVE_ON_M500
    #endif
    // @section extras
    // Arc interpretation settings:
    #define ARC_SUPPORT  // Disabling this saves ~2738 bytes
    #define MM_PER_ARC_SEGMENT 1
    #define N_ARC_CORRECTION 25
    // Support for G5 with XYZE destination and IJPQ offsets. Requires ~2666 bytes.
    #define BEZIER_CURVE_SUPPORT
    // G38.2 and G38.3 Probe Target
    // Enable PROBE_DOUBLE_TOUCH if you want G38 to double touch
    //#define G38_PROBE_TARGET
    #if ENABLED(G38_PROBE_TARGET)
      #define G38_MINIMUM_MOVE 0.0275 // minimum distance in mm that will produce a move (determined using the print statement in check_move)
    #endif
    // Moves (or segments) with fewer steps than this will be joined with the next move
    #define MIN_STEPS_PER_SEGMENT 6
    // The minimum pulse width (in s) for stepping a stepper.
    // Set this if you find stepping unreliable, or if using a very fast CPU.
    #define MINIMUM_STEPPER_PULSE 0 // (s) The smallest stepper pulse allowed
    // @section temperature
    // Control heater 0 and heater 1 in parallel.
    //#define HEATERS_PARALLEL
    //================================= Buffers =================================
    // @section hidden
    // The number of linear motions that can be in the plan at any give time.
    // THE BLOCK_BUFFER_SIZE NEEDS TO BE A POWER OF 2, i.g. 8,16,32 because shifts and ors are used to do the ring-buffering.
      #define BLOCK_BUFFER_SIZE 16 // SD,LCD,Buttons take more memory, block buffer needs to be smaller
    #else
      #define BLOCK_BUFFER_SIZE 16 // maximize block buffer
    #endif
    // @section serial
    // The ASCII buffer for serial input
    #define MAX_CMD_SIZE 96
    #define BUFSIZE 4
    // Transfer Buffer Size
    // To save 386 bytes of PROGMEM (and TX_BUFFER_SIZE+3 bytes of RAM) set to 0.
    // To buffer a simple "ok" you need 4 bytes.
    // For ADVANCED_OK (M105) you need 32 bytes.
    // For debug-echo: 128 bytes for the optimal speed.
    // Other output doesn't need to be that speedy.
    // :[0, 2, 4, 8, 16, 32, 64, 128, 256]
    #define TX_BUFFER_SIZE 0
    // Enable an emergency-command parser to intercept certain commands as they
    // enter the serial receive buffer, so they cannot be blocked.
    // Currently handles M108, M112, M410
    // Does not work on boards using AT90USB (USBCON) processors!
    //#define EMERGENCY_PARSER
    // Bad Serial-connections can miss a received command by sending an 'ok'
    // Therefore some clients abort after 30 seconds in a timeout.
    // Some other clients start sending commands while receiving a 'wait'.
    // This "wait" is only sent when the buffer is empty. 1 second is a good value here.
    //#define NO_TIMEOUTS 1000 // Milliseconds
    // Some clients will have this feature soon. This could make the NO_TIMEOUTS unnecessary.
    //#define ADVANCED_OK
    // @section fwretract
    // Firmware based and LCD controlled retract
    // M207 and M208 can be used to define parameters for the retraction.
    // The retraction can be called by the slicer using G10 and G11
    // until then, intended retractions can be detected by moves that only extrude and the direction.
    // the moves are than replaced by the firmware controlled ones.
    //#define FWRETRACT  //ONLY PARTIALLY TESTED
    #if ENABLED(FWRETRACT)
      #define MIN_RETRACT 0.1                //minimum extruded mm to accept a automatic gcode retraction attempt
      #define RETRACT_LENGTH 3               //default retract length (positive mm)
      #define RETRACT_LENGTH_SWAP 13         //default swap retract length (positive mm), for extruder change
      #define RETRACT_FEEDRATE 45            //default feedrate for retracting (mm/s)
      #define RETRACT_ZLIFT 0                //default retract Z-lift
      #define RETRACT_RECOVER_LENGTH 0       //default additional recover length (mm, added to retract length when recovering)
      #define RETRACT_RECOVER_LENGTH_SWAP 0  //default additional swap recover length (mm, added to retract length when recovering from extruder change)
      #define RETRACT_RECOVER_FEEDRATE 8     //default feedrate for recovering from retraction (mm/s)
    #endif
     * Filament Change
     * Experimental filament change support.
     * Adds the GCode M600 for initiating filament change.
     * Requires an LCD display.
     * This feature is required for the default FILAMENT_RUNOUT_SCRIPT.
    //#define FILAMENT_CHANGE_FEATURE
    #if ENABLED(FILAMENT_CHANGE_FEATURE)
      #define FILAMENT_CHANGE_X_POS 3             // X position of hotend
      #define FILAMENT_CHANGE_Y_POS 3             // Y position of hotend
      #define FILAMENT_CHANGE_Z_ADD 10            // Z addition of hotend (lift)
      #define FILAMENT_CHANGE_XY_FEEDRATE 100     // X and Y axes feedrate in mm/s (also used for delta printers Z axis)
      #define FILAMENT_CHANGE_Z_FEEDRATE 5        // Z axis feedrate in mm/s (not used for delta printers)
      #define FILAMENT_CHANGE_RETRACT_FEEDRATE 60 // Initial retract feedrate in mm/s
      #define FILAMENT_CHANGE_RETRACT_LENGTH 2    // Initial retract in mm
                                                  // It is a short retract used immediately after print interrupt before move to filament exchange position
      #define FILAMENT_CHANGE_UNLOAD_FEEDRATE 10  // Unload filament feedrate in mm/s - filament unloading can be fast
      #define FILAMENT_CHANGE_UNLOAD_LENGTH 100   // Unload filament length from hotend in mm
                                                  // Longer length for bowden printers to unload filament from whole bowden tube,
                                                  // shorter length for printers without bowden to unload filament from extruder only,
                                                  // 0 to disable unloading for manual unloading
      #define FILAMENT_CHANGE_LOAD_FEEDRATE 6     // Load filament feedrate in mm/s - filament loading into the bowden tube can be fast
      #define FILAMENT_CHANGE_LOAD_LENGTH 0       // Load filament length over hotend in mm
                                                  // Longer length for bowden printers to fast load filament into whole bowden tube over the hotend,
                                                  // Short or zero length for printers without bowden where loading is not used
      #define FILAMENT_CHANGE_EXTRUDE_FEEDRATE 3  // Extrude filament feedrate in mm/s - must be slower than load feedrate
      #define FILAMENT_CHANGE_EXTRUDE_LENGTH 50   // Extrude filament length in mm after filament is loaded over the hotend,
                                                  // 0 to disable for manual extrusion
                                                  // Filament can be extruded repeatedly from the filament exchange menu to fill the hotend,
                                                  // or until outcoming filament color is not clear for filament color change
      #define FILAMENT_CHANGE_NOZZLE_TIMEOUT 45   // Turn off nozzle if user doesn't change filament within this time limit in seconds
      #define FILAMENT_CHANGE_NUMBER_OF_ALERT_BEEPS 5 // Number of alert beeps before printer goes quiet
      #define FILAMENT_CHANGE_NO_STEPPER_TIMEOUT  // Enable to have stepper motors hold position during filament change
                                                  // even if it takes longer than DEFAULT_STEPPER_DEACTIVE_TIME.
      //#define PARK_HEAD_ON_PAUSE                // Go to filament change position on pause, return to print position on resume
    #endif
    // @section tmc
     * Enable this section if you have TMC26X motor drivers.
     * You will need to import the TMC26XStepper library into the Arduino IDE for this
     * (https://github.com/trinamic/TMC26XStepper.git)
    //#define HAVE_TMCDRIVER
    #if ENABLED(HAVE_TMCDRIVER)
      //#define X_IS_TMC
      //#define X2_IS_TMC
      //#define Y_IS_TMC
      //#define Y2_IS_TMC
      //#define Z_IS_TMC
      //#define Z2_IS_TMC
      //#define E0_IS_TMC
      //#define E1_IS_TMC
      //#define E2_IS_TMC
      //#define E3_IS_TMC
      //#define E4_IS_TMC
      #define X_MAX_CURRENT     1000 // in mA
      #define X_SENSE_RESISTOR    91 // in mOhms
      #define X_MICROSTEPS        16 // number of microsteps
      #define X2_MAX_CURRENT    1000
      #define X2_SENSE_RESISTOR   91
      #define X2_MICROSTEPS       16
      #define Y_MAX_CURRENT     1000
      #define Y_SENSE_RESISTOR    91
      #define Y_MICROSTEPS        16
      #define Y2_MAX_CURRENT    1000
      #define Y2_SENSE_RESISTOR   91
      #define Y2_MICROSTEPS       16
      #define Z_MAX_CURRENT     1000
      #define Z_SENSE_RESISTOR    91
      #define Z_MICROSTEPS        16
      #define Z2_MAX_CURRENT    1000
      #define Z2_SENSE_RESISTOR   91
      #define Z2_MICROSTEPS       16
      #define E0_MAX_CURRENT    1000
      #define E0_SENSE_RESISTOR   91
      #define E0_MICROSTEPS       16
      #define E1_MAX_CURRENT    1000
      #define E1_SENSE_RESISTOR   91
      #define E1_MICROSTEPS       16
      #define E2_MAX_CURRENT    1000
      #define E2_SENSE_RESISTOR   91
      #define E2_MICROSTEPS       16
      #define E3_MAX_CURRENT    1000
      #define E3_SENSE_RESISTOR   91
      #define E3_MICROSTEPS       16
      #define E4_MAX_CURRENT    1000
      #define E4_SENSE_RESISTOR   91
      #define E4_MICROSTEPS       16
    #endif
    // @section TMC2130
     * Enable this for SilentStepStick Trinamic TMC2130 SPI-configurable stepper drivers.
     * You'll also need the TMC2130Stepper Arduino library
     * (https://github.com/teemuatlut/TMC2130Stepper).
     * To use TMC2130 stepper drivers in SPI mode connect your SPI2130 pins to
     * the hardware SPI interface on your board and define the required CS pins
     * in your `pins_MYBOARD.h` file. (e.g., RAMPS 1.4 uses AUX3 pins `X_CS_PIN 53`, `Y_CS_PIN 49`, etc.).
    //#define HAVE_TMC2130
    #if ENABLED(HAVE_TMC2130)
      // CHOOSE YOUR MOTORS HERE, THIS IS MANDATORY
      //#define X_IS_TMC2130
      //#define X2_IS_TMC2130
      //#define Y_IS_TMC2130
      //#define Y2_IS_TMC2130
      //#define Z_IS_TMC2130
      //#define Z2_IS_TMC2130
      //#define E0_IS_TMC2130
      //#define E1_IS_TMC2130
      //#define E2_IS_TMC2130
      //#define E3_IS_TMC2130
      //#define E4_IS_TMC2130
       * Stepper driver settings
      #define R_SENSE           0.11  // R_sense resistor for SilentStepStick2130
      #define HOLD_MULTIPLIER    0.5  // Scales down the holding current from run current
      #define INTERPOLATE          1  // Interpolate X/Y/Z_MICROSTEPS to 256
      #define X_CURRENT         1000  // rms current in mA. Multiply by 1.41 for peak current.
      #define X_MICROSTEPS        16  // 0..256
      #define Y_CURRENT         1000
      #define Z_CURRENT         1000
      //#define X2_CURRENT      1000
      //#define X2_MICROSTEPS     16
      //#define Y2_CURRENT      1000
      //#define Y2_MICROSTEPS     16
      //#define Z2_CURRENT      1000
      //#define Z2_MICROSTEPS     16
      //#define E0_CURRENT      1000
      //#define E0_MICROSTEPS     16
      //#define E1_CURRENT      1000
      //#define E1_MICROSTEPS     16
      //#define E2_CURRENT      1000
      //#define E2_MICROSTEPS     16
      //#define E3_CURRENT      1000
      //#define E3_MICROSTEPS     16
      //#define E4_CURRENT      1000
      //#define E4_MICROSTEPS     16
       * Use Trinamic's ultra quiet stepping mode.
       * When disabled, Marlin will use spreadCycle stepping mode.
      #define STEALTHCHOP
       * Let Marlin automatically control stepper current.
       * This is still an experimental feature.
       * Increase current every 5s by CURRENT_STEP until stepper temperature prewarn gets triggered,
       * then decrease current by CURRENT_STEP until temperature prewarn is cleared.
       * Adjusting starts from X/Y/Z/E_CURRENT but will not increase over AUTO_ADJUST_MAX
       * Relevant g-codes:
       * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given.
       * M906 S1 - Start adjusting current
       * M906 S0 - Stop adjusting current
       * M911 - Report stepper driver overtemperature pre-warn condition.
       * M912 - Clear stepper driver overtemperature pre-warn condition flag.
      //#define AUTOMATIC_CURRENT_CONTROL
      #if ENABLED(AUTOMATIC_CURRENT_CONTROL)
        #define CURRENT_STEP          50  // [mA]
        #define AUTO_ADJUST_MAX     1300  // [mA], 1300mA_rms = 1840mA_peak
        #define REPORT_CURRENT_CHANGE
      #endif
       * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD.
       * This mode allows for faster movements at the expense of higher noise levels.
       * STEALTHCHOP needs to be enabled.
       * M913 X/Y/Z/E to live tune the setting
      //#define HYBRID_THRESHOLD
      #define X_HYBRID_THRESHOLD     100  // [mm/s]
      #define X2_HYBRID_THRESHOLD    100
      #define Y_HYBRID_THRESHOLD     100
      #define Y2_HYBRID_THRESHOLD    100
      #define Z_HYBRID_THRESHOLD       4
      #define Z2_HYBRID_THRESHOLD      4
      #define E0_HYBRID_THRESHOLD     30
      #define E1_HYBRID_THRESHOLD     30
      #define E2_HYBRID_THRESHOLD     30
      #define E3_HYBRID_THRESHOLD     30
      #define E4_HYBRID_THRESHOLD     30
       * Use stallGuard2 to sense an obstacle and trigger an endstop.
       * You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin.
       * If used along with STEALTHCHOP, the movement will be louder when homing. This is normal.
       * X/Y_HOMING_SENSITIVITY is used for tuning the trigger sensitivity.
       * Higher values make the system LESS sensitive.
       * Lower value make the system MORE sensitive.
       * Too low values can lead to false positives, while too high values will collide the axis without triggering.
       * It is advised to set X/Y_HOME_BUMP_MM to 0.
       * M914 X/Y to live tune the setting
      //#define SENSORLESS_HOMING
      #if ENABLED(SENSORLESS_HOMING)
        #define X_HOMING_SENSITIVITY  19
        #define Y_HOMING_SENSITIVITY  19
      #endif
       * You can set your own advanced settings by filling in predefined functions.
       * A list of available functions can be found on the library github page
       * https://github.com/teemuatlut/TMC2130Stepper
       * Example:
       * #define TMC2130_ADV() { \
       *   stepperX.diag0_temp_prewarn(1); \
       *   stepperX.interpolate(0); \
      #define  TMC2130_ADV() {  }
    #endif // ENABLED(HAVE_TMC2130)
    // @section L6470
     * Enable this section if you have L6470 motor drivers.
     * You need to import the L6470 library into the Arduino IDE for this.
     * (https://github.com/ameyer/Arduino-L6470)
    //#define HAVE_L6470DRIVER
    #if ENABLED(HAVE_L6470DRIVER)
      //#define X_IS_L6470
      //#define X2_IS_L6470
      //#define Y_IS_L6470
      //#define Y2_IS_L6470
      //#define Z_IS_L6470
      //#define Z2_IS_L6470
      //#define E0_IS_L6470
      //#define E1_IS_L6470
      //#define E2_IS_L6470
      //#define E3_IS_L6470
      //#define E4_IS_L6470
      #define X_K_VAL           50 // 0 - 255, Higher values, are higher power. Be careful not to go too high
      #define X_OVERCURRENT   2000 // maxc current in mA. If the current goes over this value, the driver will switch off
      #define X_STALLCURRENT  1500 // current in mA where the driver will detect a stall
      #define X2_K_VAL          50
      #define X2_OVERCURRENT  2000
      #define X2_STALLCURRENT 1500
      #define Y_K_VAL           50
      #define Y_OVERCURRENT   2000
      #define Y_STALLCURRENT  1500
      #define Y2_K_VAL          50
      #define Y2_OVERCURRENT  2000
      #define Y2_STALLCURRENT 1500
      #define Z_K_VAL           50
      #define Z_OVERCURRENT   2000
      #define Z_STALLCURRENT  1500
      #define Z2_K_VAL          50
      #define Z2_OVERCURRENT  2000
      #define Z2_STALLCURRENT 1500
      #define E0_K_VAL          50
      #define E0_OVERCURRENT  2000
      #define E0_STALLCURRENT 1500
      #define E1_K_VAL          50
      #define E1_OVERCURRENT  2000
      #define E1_STALLCURRENT 1500
      #define E2_K_VAL          50
      #define E2_OVERCURRENT  2000
      #define E2_STALLCURRENT 1500
      #define E3_K_VAL          50
      #define E3_OVERCURRENT  2000
      #define E3_STALLCURRENT 1500
      #define E4_K_VAL          50
      #define E4_OVERCURRENT  2000
      #define E4_STALLCURRENT 1500
    #endif
     * TWI/I2C BUS
     * This feature is an EXPERIMENTAL feature so it shall not be used on production
     * machines. Enabling this will allow you to send and receive I2C data from slave
     * devices on the bus.
     * ; Example #1
     * ; This macro send the string "Marlin" to the slave device with address 0x63 (99)
     * ; It uses multiple M260 commands with one B<base 10> arg
     * M260 A99  ; Target slave address
     * M260 B77  ; M
     * M260 B97  ; a
     * M260 B114 ; r
     * M260 B108 ; l
     * M260 B105 ; i
     * M260 B110 ; n
     * M260 S1   ; Send the current buffer
     * ; Example #2
     * ; Request 6 bytes from slave device with address 0x63 (99)
     * M261 A99 B5
     * ; Example #3
     * ; Example serial output of a M261 request
     * echo:i2c-reply: from:99 bytes:5 data:hello
    // @section i2cbus
    //#define EXPERIMENTAL_I2CBUS
    #define I2C_SLAVE_ADDRESS  0 // Set a value from 8 to 127 to act as a slave
    // @section extras
     * Spindle & Laser control
     * Add the M3, M4, and M5 commands to turn the spindle/laser on and off, and
     * to set spindle speed, spindle direction, and laser power.
     * SuperPid is a router/spindle speed controller used in the CNC milling community.
     * Marlin can be used to turn the spindle on and off. It can also be used to set
     * the spindle speed from 5,000 to 30,000 RPM.
     * You'll need to select a pin for the ON/OFF function and optionally choose a 0-5V
     * hardware PWM pin for the speed control and a pin for the rotation direction.
     * See http://marlinfw.org/docs/configuration/laser_spindle.html for more config details.
    //#define SPINDLE_LASER_ENABLE
    #if ENABLED(SPINDLE_LASER_ENABLE)
      #define SPINDLE_LASER_ENABLE_INVERT   false  // set to "true" if the on/off function is reversed
      #define SPINDLE_LASER_PWM             true   // set to true if your controller supports setting the speed/power
      #define SPINDLE_LASER_PWM_INVERT      true   // set to "true" if the speed/power goes up when you want it to go slower
      #define SPINDLE_LASER_POWERUP_DELAY   5000   // delay in milliseconds to allow the spindle/laser to come up to speed/power
      #define SPINDLE_LASER_POWERDOWN_DELAY 5000   // delay in milliseconds to allow the spindle to stop
      #define SPINDLE_DIR_CHANGE            true   // set to true if your spindle controller supports changing spindle direction
      #define SPINDLE_INVERT_DIR            false
      #define SPINDLE_STOP_ON_DIR_CHANGE    true   // set to true if Marlin should stop the spindle before changing rotation direction
       *  The M3 & M4 commands use the following equation to convert PWM duty cycle to speed/power
       *  SPEED/POWER = PWM duty cycle * SPEED_POWER_SLOPE + SPEED_POWER_INTERCEPT
       *    where PWM duty cycle varies from 0 to 255
       *  set the following for your controller (ALL MUST BE SET)
      #define SPEED_POWER_SLOPE    118.4
      #define SPEED_POWER_INTERCEPT  0
      #define SPEED_POWER_MIN     5000
      #define SPEED_POWER_MAX    30000    // SuperPID router controller 0 - 30,000 RPM
      //#define SPEED_POWER_SLOPE      0.3922
      //#define SPEED_POWER_INTERCEPT  0
      //#define SPEED_POWER_MIN       10
      //#define SPEED_POWER_MAX      100      // 0-100%
    #endif
     * M43 - display pin status, watch pins for changes, watch endstops & toggle LED, Z servo probe test, toggle pins
    //#define PINS_DEBUGGING
     * Auto-report temperatures with M155 S<seconds>
    //#define AUTO_REPORT_TEMPERATURES
     * Include capabilities in M115 output
    //#define EXTENDED_CAPABILITIES_REPORT
     * Volumetric extrusion default state
     * Activate to make volumetric extrusion the default method,
     * with DEFAULT_NOMINAL_FILAMENT_DIA as the default diameter.
     * M200 D0 to disable, M200 Dn to set a new diameter.
    //#define VOLUMETRIC_DEFAULT_ON
     * Enable this option for a leaner build of Marlin that removes all
     * workspace offsets, simplifying coordinate transformations, leveling, etc.
     *  - M206 and M428 are disabled.
     *  - G92 will revert to its behavior from Marlin 1.0.
    //#define NO_WORKSPACE_OFFSETS
     * This affects the way Marlin outputs blacks of spaces via serial connection by multiplying the number
     * of spaces to be output by the ratio set below.  This allows for better alignment of output for commands
     * like G29 O, which renders a mesh/grid.
     * For clients that use a fixed-width font (like OctoPrint), leave this at 1.0; otherwise, adjust
     * accordingly for your client and font.
    #define PROPORTIONAL_FONT_RATIO 1.0
    #endif // CONFIGURATION_ADV_H
  4. #4
    Super Moderator Roxy's Avatar
    Apr 2014
    Location
    Lone Star State
    It looks like the servo's are turned on. (for one servo). You should be able to do a M280 P0 S45 or M280 P0 S90 to move the servo if it is plugged into the servo 0 connector.
    You need power for it too!!!
  5. #5
    I have the 3 pins connected to the PMWEXT connection - pins 1(+5V), 2(Grnd), and 5(Signal).
    Do I need to move the connection to a different place?
  6. #6
  7. #7
    Apr 2014
    Location
    Lone Star State
    Yikes! I didn't know the Rambo board did not have servo connectors on it. That really limits where it can be used!
  8. #8
    Which is why I'm reaching out for help lol.
  9. #9
    Apr 2014
    Location
    Lone Star State
    In the Rambo pins file, it says...
    // Servos
    #define SERVO0_PIN 22 // Motor header MX1
    #define SERVO1_PIN 23 // Motor header MX2
    #define SERVO2_PIN 24 // Motor header MX3
    #define SERVO3_PIN 5 // PWM header pin 5
    I think the 'smart' thing to do is find where pin 22 is on your board. If you can't find a picture that details it... You can turn on the pin debugging and use an LED to look for it at various locations. You would do a M43 T S22 E22 R999 W300 and look for a pin that makes the LED blink.
  10. #10
    I'm wondering if I can somehow switch SERV0 PIN 22 to SERV0 PIN 5 and keep it connected like I have it...
    I'll try this later tonight and if that doesn't work - try the LED trick to hunt down the actual PIN 22 and go from there.
    Will report back later.
    Quote Originally Posted by Roxy View Post
    // Servos
Page 1 of 4 123 ... LastLast
