01-26-2017, 12:39 AM #1
- Jan 2017
Anet A8 Printer acting weird when send in a print???
Hi, I am new to making 3D Printers and got the Anet A8 3D Printer put it together and everything worked perfectly until I Sent in a print with Cura.exe and even tried to do it on micro usb but got the same results.
What happens is when I send the print in it says its starting to print and moves to get into position but when it hits the z axis endstop the z axis left motor moves the bar upwards fast but the z axis right motor doesn't move it up also when it says its printing no filament comes out of hotend even though if I push it through it does come out as seen in this video:
https://www.dropbox.com/s/idsze3fvgs95vkr/load%20noise.mp4?dl=0
Also I am getting red flashing lights on the Anet A8 motherboard as seen in this video:
https://www.dropbox.com/s/lctowsc23ru3jmg/blinking%20lights.mp4?dl=0
Here is a picture of the error code when I canceled the print on Cura.exe if that helps:
https://www.dropbox.com/s/yugtzqqdfvs5xpn/20170125_170931.jpg?dl=0
I am stumped and don't know what to do. I hope someone can help me out and knows whats going on.
Thanks in Advance!Last edited by cam100100; 01-26-2017 at 12:48 AM.
01-26-2017, 08:22 PM #2
01-28-2017, 03:05 AM #3
- Jan 2017
Yes but now filament wont extrude and have no idea why?
I did check the securing screws in the extruder gear as seen here: https://www.dropbox.com/s/1biep3nloz...03847.jpg?dl=0
https://www.dropbox.com/s/khtl2l3akl...03506.jpg?dl=0
I also tried controlling the extruder gear on Repetier Host but that was unsuccessful as seen in this video:
https://www.dropbox.com/s/k37y6m5uc6...04904.mp4?dl=0
and it seems to all be connected correctly. I am unable to push the filament hard enough w the idler pulley is not being pressed.
I checked and set the steps per mm of the extruder to 95 on printer and in software as seen here:
https://www.dropbox.com/s/tlh7x9qkhh...04715.jpg?dl=0
https://www.dropbox.com/s/vp1xjci5ns...04828.jpg?dl=0
I see the plugs are all plugged in correctly and firmly as seen in this video:
https://www.dropbox.com/s/mbtscl4xty...72641.mp4?dl=0
