Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Gear material
  1. #11
    Engineer-in-Training
    Apr 2015
    Location
    Northern Ohio
    Might look into a worm gear translation. That will drop the speed of the final drive while letting the motor run in it's efficient range. I still think nylon is your best bet. It is produced with petrolium. When it heats up it emits an oil based self lubricating film. I wouldn't rely on material recomendations ftom unqualified individuals.
  2. #12
    Jul 2014
    And i wouldn't rely on recommendations from people called todd :-)
    Is that enough tit for tat ?
    Or do you want to continue the childish name calling and snide comments ?
  3. #13
    Student
    Feb 2017
    Location
    MONA TILES COMPOUND, NR. CHHANI CIRCLE, CHHANI ROAD, VADODARA - 390002. GUJARAT, INDIA.
    Follow vexmasales On Twitter Add vexmasales on Facebook Add vexmasales on Google+ Add vexmasales on Shapeways Add vexmasales on Thingiverse
    thanks for this valuable information.
    following is the 3d printed nylon gear print by vexma technology -
  4. #14
    Student
    Feb 2017
    Location
    following is the nylon gear print by vexma technologies. which is the best 3d printing service in gujarat
  5. #15
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    Unless the part is used in water or very moist environments, I advise nylon. As an amorphous polymer, TPU with its lower hardness will display much more fatigue over time and fail due to stress cracking. Compare TPU to a very hard bunch of spaghetti, while nylon has a more integral molecular structure that brings about its strength.
  6. #16
    Student
    Feb 2017
    Location
    LOndon
    take a look at ninjatek's new armadillo filament.
    It's a super tough very rigid polyurethane based material, 90% more abrasion resistant than nylon and stiffer than abs with much better impact resistance.
    I've just ordered a 10 metre sample to try out.
    You can contact me anytime for Course Work writing Service.
Tags for this Thread
