Results 1 to 10 of 14
12-21-2016, 02:21 PM #1
- Oakland, CA
- 935
Messages not showing up - titles only
When I click on the header, I see the title and who made the posting, but no actual messages. I'm using Chrome (which always worked before.
12-22-2016, 09:31 AM #2
Can you post a screenshot?
Anyone else having this issue?
12-23-2016, 04:23 PM #3
- Oakland, CA
- 935
Sorry, Eddie - if that was addressed to me I couldn't read it, using either Chrome or Firefox. But the ads are working great...
12-23-2016, 04:57 PM #4
Based on some observations here...
Awerby - try widening the browser pane and see if that helps.
Eddie - what seems to be happening is that there is a problem in how the first and last post shown on a page are adjusted as the browser pane is reduced. I could reproduce AW's issue by narrowing my Firefox browser window. The first and last posts shrink down to only showing one character width far sooner than they should. Posts in-between the first and last on a page seem to resize properly.
EDIT: Actually, you can see the symptom of the issue on any page - the first and posts have far more white space on the right side than the posts in-between.
12-24-2016, 06:43 AM #5
Adding another post so that my prior post isn't the first or last on the page. This should improve the odds that AW can read it.
12-26-2016, 02:45 PM #6
- Oakland, CA
- 935
Printbus' remarks are spot on; I can see his post of the 23rd, but not the one from the 24th, or the first post in this thread. (Widening the browser window helps a little, but there's a limit to how wide it can go). Until this problem gets fixed, this forum is essentially useless; I'll keep checking in occasionally, but you won't be hearing from me - or many of us, I'm afraid - until you do something about it.
Andrew Werby
www.computersculpture.com
12-31-2016, 05:43 PM #7
I ran into another aspect of this issue that I find quite annoying. If you edit one of your posts that happens to be the first or last displayed on a page, you are also presented with a significantly narrower edit window.
01-02-2017, 05:10 AM #8
- Apr 2015
- Northern Ohio
- 198
This problem came up about a month ago and seems to be related to my android devices. It does make the board useless from those devices.
01-02-2017, 02:53 PM #9
- Oakland, CA
- 935
Following a helpful suggestion from Printbus, I closed the "Sponsors" panel on the right of the screen, which improved things considerably. Maybe it will help with the android.
01-02-2017, 05:56 PM #10
- Apr 2015
- Northern Ohio
- 198
I think the problem is the sell out of the site for advertising.
