Results 21 to 30 of 57
Thread: BL Touch and Makerfarm.
11-04-2016, 09:08 PM #21
- Jul 2014
- 305
11-04-2016, 11:42 PM #22
> What leveling scheme should I use and what is the best stable version of Marlin for this?
It depends on what your need. The various bed leveling schemes all offer different advantages. The UBL (Unified Bed Leveling) branch is trying to bring the best of all the different techniques to all printer types. It is trying to make it so you don't have to pick and choose. Right now, it still doesn't work on Delta printers but that is its primary focus. It will work there soon enough. That is what it was designed to help. And so far, it doesn't do the Grid Based Leveling with a Least Squares fit on the sampled points. It will do that soon enough also, but the truth is, it isn't even needed.
Seriously... I went to to the Dollar store and got the worst piece of glass I could find. I found a picture frame and when I held it up to the light I started giggling. I got a piece of glass that has huge ups and downs on it. And one side is thicker than the other side.
But here is the important part: I can get a perfect first layer across the entire piece of glass every time. It doesn't matter where I put the part, or how it stretches across the glass. I get perfect adhesion on the first layer every time. And that piece of glass I'm printing on sucks!
11-13-2016, 10:59 AM #23
- Jul 2016
- Pennsylvania, USA
- 255
11-13-2016, 11:11 PM #24
Yeah... I apologize. Please grab the current contents of the https://github.com/MarlinFirmware/Marlin/tree/RCBugFix branch. For all practical purposes that IS RC-8. We just haven't checked with each other and all shaken our heads up and down. Trust me... That is so close to what RC-8 will be, it won't matter.
11-14-2016, 06:08 AM #25
- Jul 2016
- Pennsylvania, USA
- 255
Hi
Well ok That's what I decided to do. I'm in the middle of rewiring the 12" with a BL Touch and upgrading the firmware.
(I *do* seem to have a pices of code at work that either is or isn't the release version depending on which heads shake which ways ...).
The real question is weather I'm going to do enough with any of this to go through the whole "set up Eclipse" nonsense. I find the Arduino tools great for simple stuff. They are a bit of a pain once you get past simple stuff. Eclipse is a bit of a pain on any first setup ... who knows what I'll do.
Bob
11-14-2016, 11:07 AM #26
- Jul 2014
- 305
11-14-2016, 12:57 PM #27
- Jul 2016
- Pennsylvania, USA
- 255
Hi
I am setting it up right now on a 12" Pegasus. Once I get that running I will transfer it to the 10" Pegasus. The BL Touch is mounted to a custom extruder I came up with. It also holds mount and duct for the cooling fan. Once they both are done, they also will have dedicated +5 supplies and Rpi's to run them remotely.
I'm not real sure how much use my firmware will be to others. I'm running a SSR on the heated bed and the filament cooling fan. I have the bed offset a bit to the right of the location MakerFarm recommends. My bed limits don't work very well on a "standard" printer. They are great for doing stuff that is a bit larger than the bed. Another part of that trick is the thinner power supply that I use.
Once I get it all done I'll toss it up somewhere.
Lots of fun...
Bob
11-14-2016, 07:48 PM #28
- Jul 2014
- 305
11-14-2016, 07:57 PM #29
- Jul 2016
- Pennsylvania, USA
- 255
Hi
You may not want to compare to what I have right now. For some strange reason it does not realize the heated bed exists.....I have not quite yet made it to the BL Touch. I suspect I have something *REALY* obvious goofed up. I dropped back to the original firmware and the bed still is ok there. It's not a broken wire somewhere.
Lots of fun !!
====edit
Well, so far: Both RC-Bugfix and RC-7 have the "missing bed heater" issue. Roxy's branch for bed leveling (and the low memory warning ) seems to give me a valid bed temperature. Back to figuring out what's missing where.
BobLast edited by uncle_bob; 11-14-2016 at 08:57 PM.
11-14-2016, 11:07 PM #30
