Results 1 to 10 of 35
Thread: Banding/Wobble/Layer Shift
10-16-2016, 06:55 PM #1
- Aug 2016
- 29
What is causing these lines?
This side was facing x axis
This side was facing y axis
this side is fine
10-16-2016, 07:41 PM #2
- Aug 2016
- 29
Is this a z axis inconsistency issue? Found another thread on another forum where the problem was with a loose coupler. Where are the couplers located? Idk what to check
10-17-2016, 03:27 PM #3
slicer, speed of printing, temps. material, etc
Give us some kind of clue here :-)
10-17-2016, 03:54 PM #4
- Aug 2016
- 29
Simplify 3D
2mm layer height, 205c, 60c bed temp, 2800mm/min speed
Doing it for another part now too that I'm printing at 1800mm/min
I haven't changed the files or settings at all and the parts use to come out fine. So it has to be a mechanical thing. Using the same x3g file I used a couple weeks ago.
I checked the screws on the carriage and the screws holding the bed to the platform and all are tight.
10-17-2016, 03:55 PM #5
- Aug 2016
- 29
Sorry, and this is PLA
10-17-2016, 04:23 PM #6
- Jun 2016
- Oklahoma
- 904
Was the good side facing the Z axis screw? If so I might bet it is a little dry. I had that happen on one of my printers that the Z screw was sticky and was causing the platform to shift slightly as it moved.
10-17-2016, 04:45 PM #7
- Aug 2016
- 29
Yes the good side was facing the z axis threaded rod.
10-17-2016, 05:04 PM #8
- Jun 2016
- Oklahoma
- 904
10-17-2016, 07:05 PM #9
- Aug 2016
- 29
10-17-2016, 07:47 PM #10
- Jun 2016
- Oklahoma
- 904
Do bed magnets deteriorate.
