05-12-2016, 07:23 AM #1
- May 2016
20x20x10mm Calibration Question - Z18
Hello! This would be my first post!
I'm a newbie at 3D printing but have been playing around with our new Makerbot Replicator Z18. When i print a 20x20x10mm cube on ANY of the default settings in "Makerbot Desktop" the X & Y size are quite accurate, but the Z size comes out to around 10.2-10.25. I've even went in and tweaked around with a few of the settings but not much change with the overall size.
My question is, What settings would I tweak to get the Z axis size closer to the actual 10mm like it is supposed to be?
With the over abundance of settings to tweak, there has to be something in there that will affect how tall the part comes out, other than changing the actual size of the model to compensate.
Thanks is advance for any advice!
05-12-2016, 08:17 AM #2
you would need to manually alter the steps/mm via the g-code.
05-12-2016, 08:50 AM #3
- May 2016
06-04-2016, 03:01 PM #4
- Feb 2016
- 24
Sounds like you might need to do an Esteps calibration.
Okay, a quick explanation:
The printer motors run in "steps," which are units of rotation.
Inside the printer's controlling CPU are settings that tell the printer how many steps equal one millimeter (steps/mm).
The Esteps for your Z axis motor are off, and need to be re-calibrated.
I'd suggest looking up "E steps calibration." I only really know how to calibrate the Esteps for the extruders myself.
Oh, and you can access your printer's eeprom from the "Devices" drop-down menu in Makerbot Desktop. The button "Device Preferences" is the eeprom settings.
FIRST THOUGH: If you go through with this, please make sure you know exactly what you are doing, if you mess up your eeprom, you could possibly damage your printer.
06-06-2016, 09:03 AM #5
Do bed magnets deteriorate.
