04-21-2016, 05:15 PM #1
- Apr 2016
- 6
[Question] "Error: Input file no longer exists!" Help!
Hi! I use a Makerbot Replicator 2x, and lately it has been giving me the titular error whenever I try to print. Attached is an example of a file I tried to print. messenger tier 3.stl
edit: I've combed the web and asked in several other places, to no avail.Last edited by Tantalizing; 04-21-2016 at 05:44 PM.
04-26-2016, 11:15 AM #2
okay that is weird.
The link loads 2 files.
frantic_amur.stl
is it supposed to do that ?
I can slice it okay in simplify3d. But it looks like the file is damaged and your slicer is telling you it's confused that the file loads 2 objects even though there is only one object on the build plate.
Okay I've seperated the two files (which appear to be identical) and exported the frantic-Amur stl so try this:frantic_amur.stl
Just looks like the file header was corrupted.Last edited by curious aardvark; 04-26-2016 at 11:23 AM.
05-02-2016, 05:44 AM #3
- Apr 2016
- 6
Interestingly, the frantic-Amur stl isn't anything like the part I designed. I think I may have resolved what the issue is. Here is another file demonstrating what I was trying to make.
Today, 10:12 AM in Tips, Tricks and Tech Help
