03-01-2014, 06:00 AM #1
- Mar 2014
Technical specifications of 3d printed ABS
Dear forum users,
My question is about the strengt stats of 3d printed ABS, i'm interested in this for i'm desiging a string stopper for archery in SolidWorks. Ofcourse i want to run simulations on its estimated strengt so that the actual prototype won t break into pieces becouse of the shock and viberations.
I have tried google, but didn't find much tho. The things i did find was that ABS is suposed to withstand viberations really well, and that a 3d ABS printed object would have somewhere between 30 and 60% of the strength compared to the same object but then cast with ABS, these numbers where total speculation and didn't find any evedence to backup those numbers.
The force the stopper has to with stand is a 2 gram (= 1/3 of total string mass) string moving at a estimated maximum speed of 90 meters/second and stops in a estimated 3mm resulting in a force of about 3500 Newton if i didn't make any mistakes.
I hope you people can help me solve these things.
Thanks in advance for any help given.
Kind regards,
Frank MC
03-01-2014, 07:02 AM #2
03-03-2014, 07:08 AM #3
- Mar 2014
03-03-2014, 08:55 AM #4
Well i done a pull test with a piece of 100 procent infill ABS,
It was 10mm width and 5thick i believe.
It was around 250 newton to get it sepperated and 3.2mm stretched out.
I forgot to look on how much it needed on its highest strength, But that was somewhat the number ive seen throughout the stretching process.
Done the same for PLA it was also around the 200 i believe, thats like a month ago so i aint fully sure ^^
Also those sticks where made when my printer didnt extrude enough plastic, So probably it would have had more strength if i redid it, PLA stretched back then 2.9mm.
03-09-2014, 06:00 PM #5
- Mar 2014
Do bed magnets deteriorate.
