Thread: no time
12-07-2015, 10:45 AM #1
- Jan 2015
- 14
no time
dear all ive downloaded the latest makerbot software all is fine except there is now no estimated print time it shows 000000 nothing else any advice please
thanks in advance
dave anderson
12-08-2015, 02:50 AM #2
I don't have a makerbot but... there are some tricks that can help with any slicer issue :
- have you tried to have your model checked in netfabb ?
- have you tried moving around the part before slicing ?
- have you tried changing the 1st layer thickness ?
If none works then downgrade back to previous soft working version ... sorry
12-08-2015, 03:50 AM #3
I agree with Lambda, install an earlier version that worked. Newer is not always better.
It can happen that your model is not knitted properly and the lack of time is the software's way of telling you the slice failed, but even then you should get a warning of some kind. Downgrade first and try again.
12-09-2015, 02:46 PM #4
- Jan 2015
- 14
thanks for the replies Ive done as you've said gone back to an earlier version and all is now fine thanks for your help
dave anderson
