Results 1 to 10 of 26
11-25-2015, 06:50 AM #1
Woah, What a difference... Is there something else going on here?
Over the last few weeks I've been reading about how adding a cooling fan to the FFCP could improve ABS printing results. I was skeptical, but thought It's not a difficult modification so 'Why Not'. I printed a calibration step cube before and after the mod...
It looks like they are printing in 2 different resolutions?
Left is after mod, right before mod.
11-25-2015, 07:44 AM #2
It may look better but both are overextruded. It's possible also that you are melting at too high of temp, that's why the right one is so glossy. I say overextruded since even the cooled one has many rounded corners where they should be sharp. I've never printed that piece, but I am pretty sure all the corners are sharp and square.
11-25-2015, 08:29 AM #3
Using S3D, what are some ways to fix the over-extruding? The cube is printed in Hatchbox ABS@ 230c with a bed (glass) temp of 115c. all other settings are default.
11-25-2015, 09:04 AM #4
Set the correct average filament diameter. Then adjust extrusion multiplier. .92 is a good multiplier to start with. 115c for the bed temp is way hot for ABS. Use 90-95c. Use ABS slurry on glass, apply slurry when glass reaches 90c+.
11-25-2015, 09:18 AM #5
11-25-2015, 09:23 AM #6
Print at 100% infill also. What size is the model you printed? The base model is pretty small. Did you enlarge it any?
11-25-2015, 09:50 AM #7
I didn't make any modification to the model, as I believe it design is specific to calibration. Once I have the next print complete I'll try and understand what to do with it..
11-25-2015, 09:51 AM #8
This is the model http://www.thingiverse.com/thing:24238
11-25-2015, 10:39 AM #9
There's No need for the Extra fan at nozzles !
Just Lower the nozzle-temp instead !
I've noticed that Many people run nozzle-temp way Too high.
and the extra fan really gets in the way when working on or cleaning extruders.
The X & Y stepper-motors probably Do need a fan though.Last edited by EagleSeven; 11-25-2015 at 10:46 AM.
11-25-2015, 11:04 AM #10
Jfkansas is spot-on the money. Calibrate your extruders and use the correct temps.
