Results 21 to 30 of 62
Thread: Show your RepRap Printers
10-27-2013, 08:03 PM #21
- Richmond - Tasman - New Zealand
- 6
Wow, it's like a Dr Who episode where everyone is called Simon. My OB1.4 has a build area close to 200x200x200 depending on the extruder setup. Several other people have come up with better extruders and x-carriages now so I would probably use one of them if I were building another.
I have pretty much moved on from this printer now and am working on two other designs, one is a very simple printer made from 8-10mm acrylic sheet and will be a kit sold via a friend of mine in flat pack and the other is a one-off larger scale printer I am building with Misumi 2020 type extrusions and will have a build area of 300x300x300.
I am also associated with two different builders who are building very large scale 1mx1mx1m machines both running mach3 - it seems the way to go with bigger machines as there are a lot of CNC 4-axis boards out there that will run the larger stepper motors easily.
10-27-2013, 09:33 PM #22
Seems like a very sturdy printer ^^
also as looks go you could make it pretty nice like black beams and orange plastic parts and a black or orange heated bed :P
Also i might be wrong but wouldnt it be possible to make a folding replicator from it with a few diffrent things? ^^
I just find those printers cute haha :P
But ye realy nice printer design you did there ^^
You should make a kickstarter haha :P
Edit: Just watched your video with the Red OB1 you made, Looked rly nice ^^
11-26-2013, 09:36 AM #23
This is "Jon"
It's name is Jon because that's where you go to take a s***, not really, it does some interesting things.jon (1).jpg Just almost finished with some upgrades, so I can measure and control temperature at more points. It is VERY old, like myself, has a lot of problems with the design, I change them once in a while, but for research purposes it works alright.
I'm not so much into the actual printing as know about the temperatures, and physics behind everything. I have a sales site, but it is only to support research, don't really try to sell.Last edited by Vanguard; 11-26-2013 at 09:40 AM.
11-27-2013, 10:30 AM #24
- Nov 2013
- Gedser, Denmark
Hi Printers out there.
My printer is RepRapPro Mendel with a Melzi board. It is still in the testing phase, but the only thing I need to do, is calibrathing the extruder. Then is it time for printing. Here is a picture of the animal: Img_4517.jpg
11-27-2013, 02:36 PM #25
- Nov 2013
- 8
this is our printer with double extruder and increased printing surface using 2 heated plates.
We also got 3 prusa i3 printers and 1 prusai2, but they are standard.
thought this one would fit better here.
we're changing the extruder build because now it is not easy accesible.
12-02-2013, 09:53 AM #26
12-02-2013, 01:18 PM #27
Did you just run two build plates and lock them onto one belt, than cut the borosilicate glass double long? I imaging you have to run a second PS to heat up the second HBP? Looks good!
12-06-2013, 04:39 PM #28
- Nov 2013
- Haram, Giza, Egypt
- 22
I've made my own design for the mechanical structure ... and um using the RepRap electronics .. here is my machine ... coming live very soon
03-01-2014, 10:49 AM #29
Heres my baby : (I extended all my wires and with a acrylic sheet, I mounted everything under the heated bed..One change I have made since this picture is switching out my RAMPS v1.4/Arduino Mega 2560 for a RAMBo v1.2 board from ultimachine.com....VERY happy with it.
03-20-2014, 02:23 PM #30
- Mar 2014
- Vienna
- 47
A lot of great stuff here!
Thats mine: Prusa i3XL with some modifications, but still work in progress.
L1010665.jpgLast edited by ciutateivissa; 09-13-2017 at 09:35 AM.
