Results 1 to 10 of 25
Thread: Bed-plate Extender brackets ?
10-03-2015, 06:22 PM #1
Has anyone here tried the Bed-platform extender-brackets, available at thingiverse ?
They increase bed size from 6"x9" to 8"x10", then put 8"x10" glass or mirror on top.
I want to find how well they work and if the extra space can really be Used,
before printing them and getting glass cut for it ??
I can see that there may be problems with them ?
http://www.thingiverse.com/thing:911670
Click picture for larger view:
CTC bed extender 1.jpgLast edited by EagleSeven; 10-12-2015 at 03:44 PM.
10-04-2015, 08:10 AM #2
- 441
That's pretty nifty. Not that I can help you, but maybe when I get mine we shall give it a shot :P
10-06-2015, 02:11 PM #3
I was looking at these bed-extenders more closely
and I think the left nozzle will hit the part of extender that sticks up above glass,
at left front corner of bed, when it does the clean-out pass at start of prints.
(if nozzles are at Same height for Dual filament prints)
So, I think I will let You try them before I install them ! LOL
Note: I think that corner could be sanded down to be flush with glass, if it's too tall
I'll go ahead and print them to see how they fit, before I get the glass.Last edited by EagleSeven; 10-06-2015 at 03:33 PM.
10-06-2015, 04:21 PM #4
I printed 2 of the corners and they look great, starting the other 2 now.
Used PLA and added Rafts and supports, which I usually do not do,
since there are long overhangs on bottom sides and strength is more important than making bottom look-good.
Not sure if one corner will need to be sanded or not , but will be easy to do if needed.
Will not install them until I get the 8"x10" glass.
10-07-2015, 09:04 AM #5
Update: I discovered that by changing printer type from Replicator-Dual to Replicator-2
the bed-platform width is Enlarged in Makerbot slicer software.
(and Replicator-2X size is between those 2)
So, maybe the 10" wide bed can really be Used !
Suppose I won't know for Sure until I Try it !Last edited by EagleSeven; 10-07-2015 at 12:35 PM.
10-07-2015, 01:21 PM #6
Another discovery :
I found that to take advantage of Replicator-2 setting it is best to re-position the corner pieces,
since it enlarges in X direction and not in Y direction.
So, now the size of glass needed is 11 1/8" X 6 7/8" !
2" gain in the X direction, which is Great.
Sure glad I checked all this before getting Glass cut !Last edited by EagleSeven; 10-07-2015 at 02:38 PM.
10-07-2015, 02:03 PM #7
In this picture you can see how corner brackets were re-positioned to make bed wider in X direction.
Compare it to picture from thingiverse, in previous post.
(this is with No glass sheet installed yet.)
Note: I now have new glass installedLast edited by EagleSeven; 10-07-2015 at 02:38 PM.
10-07-2015, 02:40 PM #8
Did a Test and it will print the Full 11" width, if needed !
So the Extenders Do work !
??? Curious what the 7532 means, that was added in previous post listing??Last edited by EagleSeven; 10-07-2015 at 03:54 PM.
10-09-2015, 01:56 PM #9
Admin,
Why are Not all my messages being displayed, in this thread ??
Last ones have been Cut-Off !
Shouldn't there be a page 2 or something ??Last edited by EagleSeven; 10-09-2015 at 02:07 PM.
10-09-2015, 02:47 PM #10
- 441
