Results 1 to 8 of 8
Thread: having issues
09-03-2015, 06:07 PM #1
- Aug 2015
- 12
having issues
this was printed with skeinforge
setting set at
15% infill
.25 layer height
2 shells
40 feedrate
60 travel
195 temp....
I am super new to 3d printing and have in total 25 hours experience any advice would be great!
09-04-2015, 02:27 AM #2
Not enough information:
- What material?
- HBP temp?
- Did you calibrate your extruder?
- What printer?
09-08-2015, 03:47 PM #3
- Jan 2014
- 462
Looks like you're over extruding. Have you calibrated the machine yet? http://reprap.org/wiki/Calibration
09-08-2015, 08:03 PM #4
Looks like you used too much plastic, have you measured your filament diameter?
09-09-2015, 02:07 AM #5
- Sep 2015
- 5
first ABS layer sticks at base plat (abs)
I have a problem. the printer at my work ( 250 Fortus mc ), is very good and accurate , only the first layer of abs is far too fixed on the abs plate (base plate (also abs )) .
I have ordered a super glue for bonding to take place only with the adhesive.
Do you may have a different solution to this problem?
print 4.JPGprint 2.jpgprint 1.jpgLast edited by Vink_Kunststoffen; 09-09-2015 at 02:33 AM.
09-09-2015, 02:14 AM #6
- Jun 2014
- Burnley, UK
- 1,662
How are you pulling things off the plate? You should do it by twisting the plate not trying to pull the printed item off.
09-09-2015, 02:27 AM #7
- Sep 2015
- 5
We do twist the printed items of the plate, by bend the abs support plate. Whereby the printed items break. but the fist layer stil does stick too the abs plate.
09-09-2015, 04:28 AM #8
- Jun 2014
- Burnley, UK
- 1,662
The first few layers are the raft anyway and they do not really have to come off the plate when the item does.
It is a strange problem that I have never seen before. I wonder if your plate is too high because the levelling probe is worn. Are you using Stratasys plastic?
Today, 02:02 PM in Tips, Tricks and Tech Help
