08-29-2015, 12:15 PM #1
- Aug 2015
- 15
Modifying hollow STLs in Blender to become solid
Hi guys, this is a noob question, but I'm hoping someone here knows the answer and is willing to share.
I downloaded an STL file of something with sides and a roof, but no floor (think of a plastic hotel piece from a basic Monopoly set). So when I printed it, it was somewhat fragile due to lacking any interior reinforcement. I thought it would be pretty straightforward to import the STL into Blender and then add a mesh plane to the bottom of the model, which would then allow my infill settings to provide internal reinforcement. But when I exported the combination to a new STL and printed it, nothing changed. So my first question is: Should this have worked? If so, I should try to figure out what went wrong. If not, do you have suggestions for the best way to accomplish my goal?
Thanks!
08-29-2015, 10:44 PM #2
I've used this STL Repair site in the past to fix that very problem. Easy to use and works most of the time.
https://modelrepair.azurewebsites.net/
08-30-2015, 09:35 AM #3
