08-28-2015, 08:59 AM #1
- Aug 2015
- 18
Fixed FFCx but now prints have weird seam ?
Hi All,
Well got my FFCX working again but the print has developed a weird seam just up one side, is this a bed levelling issue ?
print.jpg Any suggestions ??
Cheers
08-28-2015, 09:16 AM #2
Try turning extruder hold on in the front panel options.
08-28-2015, 09:20 AM #3
- Aug 2015
- 18
ok, never had to check that before but it does now have new motherboard and firmware so probably lots of settings pear shaped, should ditto printing be on or off ??
And thankd
08-28-2015, 09:33 AM #4
08-28-2015, 09:39 AM #5
- Aug 2015
- 18
Ok trying a print now,
Been so long, what feed and travel do you generally use for ABS.
I was running 70 & 80 previously but now with new motherboard etc have slowed it right down for this print to 40 & 70.
using the FFCx to experiment with settings before doing final prints in the new creator pro.
Thanks again for taking time out to reply.
08-28-2015, 10:56 AM #6
- Aug 2015
- 18
Well,
Just tried a different print after changing extruder selection to hold, and didn't have the issue I had with that print earlier, so sshall try the print a posted image of tomorrow as its now 02:00.
Thanks again for the helpful advise.
Cheerss
08-28-2015, 11:58 AM #7
My standard settings are 80 and 120. This is with one print head/stepper removed so that removes lots of weight.
