Results 2,541 to 2,550 of 4110
07-27-2016, 03:54 PM #2541
- Mar 2016
- 52
07-27-2016, 03:56 PM #2542
- Mar 2016
- 52
Thanks! I too am frustrated. And the language barrier between Qidi Tech and I just makes technical communication that much harder...
I read about an upcoming official 7.8 firmware... lucky us we are stuck with Qidi Tech's unknown 7.8 version, which could be based on Sailfish version 7.1 for all I know.
07-27-2016, 04:05 PM #2543
- Aug 2014
- 627
Very true and let me tell you Jetty is not a happy man about shit companies like Qidi making up SF numbers like that. He bit my head off over it so buy a quality printer that uses the real Sailfish or suffer (I am putting that in nicer words than he used on me about it).
As far as the language barrier goes I sincerely think they use that to their advantage and easily understand what we are saying. I know more Chinese can read, write, and speak English than the English can their dialect of Chinese since they go to school and English is the international language of business so China demanded they learn it. Was a wise move imo.
I also don't know if going with the Smoothieware firmware would be better or worse for this printer.Last edited by DarkAlchemist; 07-27-2016 at 04:10 PM.
07-27-2016, 04:22 PM #2544
I have a older Qidi Tech (9 months) that came with a version of firmware called Makerbot Version 1 running on a ATmega 1280 board.
About 6 months ago I decided to see if I could upgrade to Sailfish and initially thought I had bricked my board. Since I had succeeded in totally erasing all firmware from it. After a lot of googling I found the original bootloader and USB hex code for this board. I was able to load that back into the board with a programmer and AVRdude. Then I was able to load the current version of Sailfish. The problem with these boards is that Qidi Tech is using something called non standard fuse settings which makes upgrading the firmware difficult but not impossible. You just need knowledge and way to change the fuse settings. I have no idea what the newer board is using for fuse settings or what they should be.
BTW all Chinese clone makers boards are missing nearly all of the same plugs. The only printer I know of that has the LED color change working is the original Makerbots.
07-27-2016, 04:38 PM #2545
- Aug 2014
- 627
07-27-2016, 06:04 PM #2546
- Jun 2016
- Oklahoma
- 904
07-27-2016, 06:05 PM #2547
- May 2016
- Annapolis, MD
- 523
07-27-2016, 06:10 PM #2548
- Jun 2016
- Oklahoma
- 904
07-27-2016, 06:13 PM #2549
- May 2016
- Annapolis, MD
- 523
That looks great W! I actually started with a similar pin approach when I designed my version. I broke one of the pins off accidentally and shifted to re-using the original mounting screws instead. Just curious, but how much variation in thickness do you have in the acrylic on your QiDi?
07-27-2016, 06:15 PM #2550
- May 2016
- Annapolis, MD
- 523
