Results 3,861 to 3,870 of 4110
01-09-2017, 06:00 PM #3861
Hmm, looks like they have 3/16" and 1/4" listed again. 3/16" is the best.
01-09-2017, 07:01 PM #3862
- Apr 2015
- Northern Ohio
- 198
They ran out of stock a while back. This is why i ended up with the 1/8. They are restocked now. I did notice the same thing with their stock. I agree about the 3/16" plates being the best.
I live less than an hour from them and can pick up same day or get it next day for cheap. At work if i order before 9am i often get it before 3pm. I use them at least once a week for work.
I might have lucked out. I used to use kapton tape and just tried the fiance's stuff and it worked. Been using it ever since. I bet the PVA content is higher in the cheap stuff.
BTW you have some nice stuff on your website. That isolator block with the nozzle clamp screws on the side is on my list.Last edited by Todd-67; 01-09-2017 at 07:24 PM.
01-09-2017, 10:11 PM #3863
- Feb 2016
- 96
Ok this is a weird one but can someone tell me the exact dimensions of the build plate? I have like four sets of notes written down and they range from anywhere from 9x6" to 230x150, to 228x149, etc. I have seen QIDI quote different numbers on Amazon and eBay and the Flashforge Google group has instructions on setting up the machine in Octoprint and they have different numbers too. I know a few mm's don't mean much but I want to get it exactly correct.
01-10-2017, 04:11 AM #3864
Don't worry about exact. Just get 6x9 size at Mcmaster. 3/16" thick. That is 228 x 152.
01-10-2017, 06:00 AM #3865
- Jun 2016
- Oklahoma
- 904
The 6X9 fits the FFC nearly perfect size wise while it is off a little for the QIDI but still works fine.
01-10-2017, 09:18 AM #3866
01-10-2017, 09:32 AM #3867
- Nov 2015
- 43
Where did you get the knockoff hot ends? How are they working for you now? I am considering getting the E3D V6. Does it work with the Qidi Tech no problem? From what I have heard, the knock off hot ends still have a PTFE insert and do not allow you to go to the higher temperatures for nylong. For that you need an all metal hot end.
01-10-2017, 10:05 AM #3868
01-10-2017, 10:12 AM #3869
- Nov 2015
- 43
01-10-2017, 11:25 AM #3870
You'd have to redesign the whole print head.
