Thread: ABS Printing Temp with E3D V6
08-11-2015, 10:15 AM #1
- Jul 2015
- 27
Hello all I've assembled my MakerFarm 8" i3v and loving it. Colin recommended I print PLA at 225 with the E3d V6 hot end I installed and that seems to be working good. That seems high so I was wondering if anybody here has a recommended temp for ABS using it? Also does anybody know why the E3d V6 requires a higher than average temp?
08-11-2015, 10:49 AM #2
I know that for the hexagon hot end, Colin's Slic3r config files also defaulted to 225 for PLA, and 250 was the default setting for ABS.
08-11-2015, 11:52 AM #3
- Jul 2015
- 27
Thanks for that I'll keep it in mind. Have a roll of ABS coming from Colin
08-11-2015, 04:57 PM #4
- new jersey
- 752
i have 4 e3dv6's and they all run abs at 245-255 depending on brand and color.
11-05-2015, 12:31 PM #5
- Nov 2015
Just tripped over this forum. I've been printing with PLA on all of my printers without issue, but I cant get ABS to do anything right. What brand is working well for you all. I'm using gizmo dorks PLA and ABS, because the PLA I get from them is always perfect. I've tried up to 235 with my Solidoodle Workbench using E3d V6's, and I have to say I've melted a lot of useless plastic at this point. From the looks of things maybe I should go hotter. What kind of bed settings are you using? What are you using to keep things stuck down? I tried ABS juice, and it works well on my Prusa with hardware store garbage glass, but the workbench has borosilicate glass, which seems to laugh at it. I had ok luck with hairspray, but only with smaller jobs. Help!!!
Thanks,
Rick
