07-06-2015, 01:02 PM #1
- Jul 2015
- 91
Looking for a good 3D printer with good support Im looking at the Robo3d and others
I like the fact Robo3d is open source and seems to have a good following or helpful people. I like their filaments they can use like the wood stuff
and seems to use most anyones filament. I see a few new ones on Kitstarter but not sure if they will have all the bugs worked out on them for
a while. I wish the Robo3d was a little larger build platform but might do for what Im plan to build some small speaker boxes.
I wonder if I can build a hollow box rectangle or square and the walls will not warp. I plan to make them around 1/8" thick maybe 3/16.
Ive been trying to figure out how much filament it would take to build one they say 1000 grams divided by the weight of item is one one.
I wonder if the design or print software can figure that out for me so I know what it will cost to biuld a certain size object?
07-06-2015, 01:52 PM #2
right - first thing you need to do is start thinking in millimetres :-)
Second download cura and load and slice some models to get a feel for how the whole process works. No printer needed.
https://ultimaker.com/en/products/cura-software
If I'm making very strong walls for a box, I make them 2mm thick.
The walls on this little gadget are 2mm
https://www.youtube.com/watch?v=LJq_4QiewWw
Pretty strong :-)
Uses 7 grams of plastic to make.
So a hollow speaker cabinet with 2mm walls would not use much plastic at all.
Also any 'solid' object you print - won't be. It'll have solid walls and a sponge like interior that makes it strong but usues very little plastic.
The robo3d looks like decent pirnter - can't think of any negative reviews.
they say 1000 grams divided by the weight of item is one one.Last edited by curious aardvark; 07-06-2015 at 04:07 PM.
