Thread: problem with quality print
05-24-2015, 03:12 AM #1
- May 2015
hi
I Set Cura setting wiith these numbers
but why the quality in too bad
NEED HELP
IMG_6166.jpgScreenshot 2015-05-24 12.59.31.jpgScreenshot 2015-05-24 12.59.38.jpgLast edited by Nikano; 05-24-2015 at 03:30 AM.
05-29-2015, 01:54 PM #2
- May 2015
I'm not very experienced.... But that looks like a lot of variance on your x or y axis. Are the belts nice and tight?
i use slic3, the only obvious difference in the settings I could spot is the "100 % fill" mine is set to 50% and makes a lovely little honey combe pattern. (But I don't think that is your problem)
cheers
Docker
06-17-2015, 11:16 AM #3
- May 2015
Take a look at this
http://reprap.org/wiki/Print_Trouble...ictorial_Guide
Could be Z axis wobble also
06-18-2015, 04:14 AM #4
Try to put a fan close, try to see if your X & Y belts are loose, try to print another item at the same time (to increase the time between layers).
06-18-2015, 04:02 PM #5
- 462
If your belts are tight, you might have bad or worn bearings, especially on the Z axis. This is easier to check on a kit printer, as you can decouple the Z axis motors and check for free movement of the axis (it should be obvious from the sound if you've got bad bearings).
