Results 11 to 20 of 22
Thread: Help recalibraring ABL
05-24-2015, 03:52 PM #11
- Dec 2014
- 43
So I have it working now with the original numbers. Come to find out in the firmware under Additional Features define Z_PROBE_OFFSET_RANGE_MAX was set to -5.00. So when I used -4.00 it was not in range and it would just default to -5.00 and it would push the head into the glass. I change it to -3.00 and it is working just fine.
05-28-2015, 07:10 PM #12
- Dec 2014
- 43
So here is a weird thing when I put the numbers in the terminal I can print and everything is fine. Now when I put those numbers in the firmware and load it up it wants to push the nozzle about 4 mms into the glass. I have tried adjust the numbers and no matter what I use it wants to push the nozzle 4mm. I am stumped.
05-28-2015, 08:30 PM #13
- Nov 2014
- 138
In pronterface do m502 and then m500 to store setting. After flashing the firmware.
05-28-2015, 09:02 PM #14
- Dec 2014
- 43
I will try that
05-28-2015, 11:18 PM #15
- Apr 2015
- Pacific Northwest
- 24
05-28-2015, 11:36 PM #16
- Dec 2014
- 43
So the m502 and m500 commands did the trick
05-29-2015, 08:56 AM #17
This problem has been a plague to everybody trying to get Auto Bed Leveling going. Very few people actually store values in the EEPROM. But most people end up with bad values there. So when you are working to turn on Auto Bed Leveling, it is often best to just turn off the EEPROM until you have it running. That forces it to use the values #define'd in the Configuration.h file.
05-29-2015, 12:02 PM #18
- Dec 2014
- 43
Where in Marlin do I deactivate the EEPROM?
05-29-2015, 12:14 PM #19
05-29-2015, 12:48 PM #20
- Dec 2014
- 43
Thanks so much do the help
Do bed magnets deteriorate.
