Results 1 to 10 of 16
05-19-2015, 11:36 PM #1
- May 2015
- 31
One Last Question For a While.....
Is there a way to turn off the light? LOL
Thanks in advance!
05-20-2015, 03:11 AM #2
Probably can unplug it. I think you can disable in the front panel options also.
05-20-2015, 09:36 AM #3
- Apr 2015
- Northern Ohio
- 198
insert a line in the g code file containing this M146 r0 g0 b0 That will turn the lights off.
05-21-2015, 02:47 PM #4
- 441
05-22-2015, 12:06 PM #5
- Apr 2015
- Northern Ohio
- 198
The M146 command addresses the lights. The RGB values are adjusted from 0 to 255. For example M146 R255 B0 G0 would be a red light and M146 R0 B255 G0 would be blue. If you wanted purple it would be a mix of red and blue such as M146 R225 B225 G0.
Depending on what slicer you are using you can put the color change sequences at certain intervals such as pre-heat, print and post print.
05-22-2015, 01:14 PM #6
- 441
05-22-2015, 05:16 PM #7
If you're into editing a long G-code file, you probably could insert the G146 command randomly throughout the file to produce many effects. Maybe a different color depending on the direction of the axis movements? (aka Disco 3D printing....)
Also, printing in the same room you sleep? Talk about "white noise"
05-26-2015, 04:23 PM #8
- Apr 2015
- Northern Ohio
- 198
It's possible with enough gcode editing. I would be easier to just wire them to a controller like this one.
http://www.dx.com/en/p/rgb-led-light...B#.VWTj8kaX21k
That would give you full control of the lights, patterns, color and strobing effects, etc
05-20-2015, 03:31 PM #9
- May 2015
- 31
Thanks Todd!
05-21-2015, 09:38 AM #10
- Apr 2015
- Northern Ohio
- 198
