04-13-2015, 01:23 AM #1
- Feb 2015
- Flagstaff, AZ
- 73
Can't call method "clone" on unblessed refrence
Ok, sliced the 24mm cube to test my printer and it worked just fine. Next I wanted to print a knob for the lcd and I get error:
Can't call method "clone" on unblessed refrence . . . Print.pm line 157.
So I went back and tried to slice the same 24mm cube I sliced last night and now get the same error. Any idea what this is? I googled it but everything I looked at said to upgrade Slic3r but the build guide says not to update Slic3r.
04-13-2015, 01:30 AM #2
- Feb 2015
- Flagstaff, AZ
- 73
if I open the config then slice it works. I thought the loading the config would be a one time thing.
04-13-2015, 05:28 AM #3
You must load the config file every time you open slicer.
04-13-2015, 06:34 AM #4
- Jul 2014
- Eastern Colorado
- 536
You can update Slic3r. I and many others here who use Slic3r use the latest stable, 1.1.7.
04-13-2015, 10:55 AM #5
- Feb 2015
- Flagstaff, AZ
- 73
04-13-2015, 11:18 AM #6
Version 1.1.7 of Slic3r is very stable. I use it for anything important.
