Results 31 to 40 of 102
Thread: Itty Bitty Double FLEX Extruder
04-08-2015, 07:43 AM #31
04-08-2015, 08:08 AM #32
04-08-2015, 09:48 AM #33
04-09-2015, 07:15 AM #34
Got all the wire routing sorted out! Easiest way was to assembly everything without both sides of the carriage shelf...then mount them both last...this allows you to place the wires where to cut out would end up. The only thing missing in these pics is the Insulation Strip which i'll put on last..
04-11-2015, 11:21 AM #35
Yes. The large pulleys and the spacers are the same. If you're using hexagon hot ends, the servo probe arm and the print cooling fan shroud are also the same. And of course the hardware is all the same. Depending on how much you cut up the insulator, you might be able to use it. If not, I have spares available.
04-11-2015, 03:48 PM #36
- Mar 2015
- Palo Alto
- 63
Yeah. Got all assembled and found out the hard way that the carriage sides were different, doh (too stupid/lazy to just look at the stls). Managed to print the sides with the carriage just cantilevered out there. Will have to redo calibration now that the shelf is properly supported, but so far so good. Thanks again. Will get some better pictures once I get around to sleeving the wires.
Edit: will probably also look at your start code for some wipe hints after the long ABL process.
04-12-2015, 02:26 PM #37
clough42, THANK YOU!
I got the extruder finished up yesterday and calibrated using you STL's and calibration calculator, those 2 items made setting up the offsets extremely simple.
I am now printing my first successful 1.75mm
ninjaflex test print. I'd almost given up on being able to use the spool of material until this update.
Thanks Again.
04-12-2015, 08:50 PM #38
- Mar 2015
- Palo Alto
- 63
Everything was going well (still need to dial in retraction) but the extruder started skipping about 1.25 hours into the print. The Nema 14 was too hot to hold for more than a few seconds. Pretty sure it's not filament, calibration, etc. Think I will take your Nema 17 shroud to work tomorrow where I have soldiworks to see if I can make it fit the Nema 14. I'm also planning on printing out a RAMPs fan holder in case the driver is also too hot.
04-13-2015, 07:21 AM #39
04-13-2015, 07:23 AM #40
