Thread: PLA Extrusion: Broken Surfaces
01-13-2014, 07:47 PM #1
- 6
It has been a good while since I had to switch spools of PLA so maybe its some setting in slic3r I don't have right.
The grey object has a pretty uniform surface to it (not perfect but being a reprap/repstrap style printer, I'm not complaining)
The blue object is what seems to have all the breaks it seems (despite the ugliness from the semi-translucent filament)
Any thoughts on why the blue has more surface fracture looking parts?
(I have not changed any settings between using the two filaments, just reloaded the previous gcode i used with the grey only with the blue feeding)
01-13-2014, 08:12 PM #2
- new jersey
- 752
on the blue roll try turning up the temp 10 deg. see if that makes a difference
01-14-2014, 07:54 PM #3
- 6
Yay that did the trick, looks a lot better than it did before, thanks
