Thread: ABS recycling
03-19-2015, 04:24 AM #1
ABS recycling
Any good links on recycling your failed prints and scrap into new filament?
What grinders or shredders do people use?
I have a lot of prints that I don't give a hoot about color, so I'm going to be just mixing the colors into some random weirdness.
03-19-2015, 12:06 PM #2
My intention is to collect my most used colors (white, black, clear) and mix the others. Then eventually get a grinder and an extruder. I doubt I will use this homemade filament as a primary prodcution filament but I see no reason it can't be loaded in a second extruder head and be used for fill or support material on the cheap.
03-20-2015, 12:02 AM #3
- Aug 2014
- Montreal, Quebec
- 576
I had in mind to cast ABS by using a mix of acetone. Since ABS is quite flexible when hardens, it might be good use to mold at low temperature.
Do bed magnets deteriorate.
