Results 1 to 10 of 16
Thread: i need of help
02-23-2015, 10:16 AM #1
- Feb 2015
- 12
i need of help
i have a big problem with my printer i cant get it to print. the printer works and moves all the axis but the extruder motor just doesn't want move . i have connected the motor to other axis and it works. ive also switched over the driers with other axis and they work just the extruder does not to work i highly suspect that i have a problem with the Firmware i tried using Marlin but haven't managed to get it working at all. i have used reprap and that makes everything work apart from the actual extruder. Please help !! attached you can find the current firmware i am using.
it is a pursa i3 stile printer using a ramps 1.4 board with a reprap lcd . it doent really matter what firmware there is as long as it works. if any one could help me i would much appreciate it
02-23-2015, 02:11 PM #2
The very last thing I want to do is download a random zip file from the internet.
Isolate the extruder motor and see if you can get it to run on it's own. Rule out the possibility of it being a faulty motor. If you have another stepper motor, plug that into the extruder motors cable and see if it will run.
02-23-2015, 02:29 PM #3
- 462
Either enable cold extrusion or heat up the extruder before you extrude anything. Ramps won't extrude cold to prevent damage to your extruder / hotend.
02-23-2015, 03:29 PM #4
- Feb 2015
- 12
I have tried that and failed. I have tried to print an object with the correct temperature but still no extrusion. I have just noticed that in the configuration on the LCD, it says that the extruder steps/mm is 0.00 but I cannot find how to change it. Any idea how please?
02-23-2015, 03:31 PM #5
- Feb 2015
- 12
02-23-2015, 04:50 PM #6
- 462
M92 to set your extruder steps per mm http://reprap.org/wiki/G-code#M92:_S...steps_per_unit. Calibrate as per the reprap wiki guide [url]http://reprap.org/wiki/Calibration#Extrusion[url].
Your initial setting should be based on the type of extruder you have. I have a Wades, set to 711.11 steps per mm for the extruder. A direct drive extruder will have a smaller number.
02-24-2015, 03:17 AM #7
- Feb 2015
- 12
02-24-2015, 05:42 AM #8
- 462
You've lost me here. Your screen shot is too low a resolution to make anything out, and problems uploading the g code doesn't make sense without more information. Alse, M92 X350 sets steps per mm for the X axis, not the extruder. You should be able to directly send g code commands to your printer by connecting to your printer, then clicking on the "Manual Control" tab in repetier host. At the top of the panel you can enter a g code command to send to the printer.
First, set your printers extruder temperature and wait for it to get to the correct temperature.
Second, send the following g code command to the printer, to set e-steps per mm for the extruder:
M92 E500
Third, send the following g code command to the printer, to extrude 10mm of filament:
G1 E10 F100
If that works, you need to go through the E-steps per mm calibration routine in the reprap wiki.
02-24-2015, 06:46 AM #9
- Feb 2015
- 12
Thing is it says connected but than whatever i do it just stays "command waiting"
02-24-2015, 07:22 AM #10
- 462
Have you installed the driver for your board? What board do you have? How did you get the printer to move before - through Repetier host or the LCD interface?
