02-11-2015, 01:32 PM #1
- May 2014
- 16
PROBLEM: when HOMING, Z moves only UP
Before printing Z carriage was at the top, I did not pay attention and start printing. After warming, the Z carriage began to rise up to the top and was not able to move more. In that moment I turn off the power to stop printer self-destroying.
After rebooting printer I run auto-homing, X&Y works perfect, but Z moves only up.
All endstops working correctly (checked with M119 command).
I tried to disable ABL in firmware, but Z HOMING still not working ;(
PS: I have makerfarm i3 + marlin + enchanced ABL.
02-11-2015, 01:37 PM #2
- Jan 2015
- 48
Z axis cable is probably backwards. Just flip it to the opposite where it plugs into the ramps board.
Well that is if I am understanding your problem correctly.
02-11-2015, 01:49 PM #3
- May 2014
- 16
02-11-2015, 02:13 PM #4
- Nov 2014
- 522
check to make sure your Z-endstop wires aren't broken, it's a safety feature to prevent bed crashes when no endstops are detected
02-11-2015, 02:59 PM #5
- Nov 2014
- 58
you can check your enstops status with a M119 command , that happened to me when i installed the ABL and it was a loose cable.
