Thread: Extruder not heating properly
11-19-2018, 02:54 PM #1
- Nov 2018
- 9
Soooo long story short... I had a big print goint that ended up failing and leaving a huge rats nest for ABS. I cleaned up and cleard the clogs and thought all would be well. I was wrong! When i try to preheat the extruder I get a heat failure. With the fans off it heats to 120? then starts descending then kick the error. With the fans on it makes it to 45ish and does the same. The wires look ok but there is a clear wire with the ends glued together... I don't know what it does or why its near the heat block. But the wires are not exposed and the shielding is intact. Could that wire be the a ground or causeing an issue? Does anyone know what is causeing the heating to fail?
11-19-2018, 05:46 PM #2
11-19-2018, 07:38 PM #3
- Nov 2018
- 9
That's what I'm working with.
11-20-2018, 05:45 AM #4
Watch this video, it should give you some knowledge you need now about installing the heat-block thermister. Your installation may not include the white Fiber washer so skip this step. However if you have one laying around somewhere please include this washer as it will help maintain your hot-end temperature readings or you could wrap the hot-end with Teflon thermal tape.
https://www.youtube.com/watch?v=som535yus2MLast edited by Roberts_Clif; 11-25-2018 at 05:20 AM.
11-24-2018, 11:21 PM #5
- Nov 2018
- 9
QIDI Slicer "Plater" is...
