Results 1 to 9 of 9
07-10-2017, 10:37 AM #1
Marlin 1.1.4 w/ Viki2 LCD on RAMPS
Alright Roxy, I'm giving Marlin 1.1.4 a shot, but I'm having issues getting the code to compile with my somewhat unique Panucatt Viki2 LCD.
PHP Code:Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\zmoore\Downloads\170709 Marlin-1.1.4\Marlin\Marlin.ino:39:28: fatal error: LiquidTWI2.h: No such file or directory
#include <LiquidTWI2.h>
compilation terminated.
exit status 1Error compiling for board Arduino/Genuino Mega or Mega 2560.
but I'm still getting the error message. Am I putting it in the wrong spot or something? I don't see Wire.h in any of my directories, which is right above LiquidTWI2.h in the Marlin ino file.
Another detail to note: In the Arduino IDE prompt, the Wire.h text is colored orange which indicates it's actually linked to something(?), while the LiquidTWI2.h text is black.
My whole Marlin package can be downloaded here for testing:
https://1drv.ms/f/s!Aqg7KdDBqulRkHyb5w4CF-edx1DG
I'm compiling with the latest IDE 1.8.3.
07-10-2017, 03:38 PM #2
Update (Resolved):
Okay first, I had uncommented both #define VIKI2 and #define LCD_I2C_PANELOLU2, but realized I only needed to uncomment #define VIKI2. This changed my issue from #include <LiquidTWI2.h> to #include <U8Glib.h>....which was a bummer.
BUT - I figured that out. Apparently in Arduinio IDE you have to manually add libraries by Sketch->Include Library->Add .ZIP Library. I downloaded U8Glib and added it in Arduino IDE along with manually copying over U8Glib.h and U8Glib.cpp into the Marlin directory.
Compling was going well but then....bam, huge error that I'm not going to copy into this thread. The error was cryptic, but was talking about things being already defined in U8Glib, sooooo, I randomly made a guess that me manually copying over the U8Glib.h & U8Glib.cpp was a bad idea. I deleted my copies of U8Glib.h and U8Glib.cpp from the Marlin directory, recompiled and it worked!
However, I did have another error I needed to fix. The compiler was saying that my DELTA_PROBEABLE_RADIUS was not set, even though I specifically said to use AUTO_BED_LEVELING_3POINT which should not require a probe radius to be defined. Whatever, I just added #define DELTA_PROBEABLE_RADIUS 80 underneath //#define MESH_BED_LEVELING and it solved my issue. This looks like a bug though. DELTA_PROBEABLE_RADIUS is only if defined for UBL, but even with that commented out, I was still getting an error asking for it.Last edited by LuckyImperial; 07-10-2017 at 05:07 PM.
07-10-2017, 08:29 PM #3
Okay, I'm up and running. I don't have my FSR Kit installed so I haven't done any auto calibration but even with my manual calibration it's printing quite well. So far no skipping with my 8bit processor, even at 200 segments/mm, so that's pretty rad.
I guess I should also note that I had to make some tweaks in the pins_RAMPS.h file for the viki2 LCD to start working.
Code:#elif ENABLED(VIKI2) || ENABLED(miniVIKI) #define BEEPER_PIN 35 // Pins for DOGM SPI LCD Support #define DOGLCD_A0 47 #define DOGLCD_CS 32 #define LCD_SCREEN_ROT_180 #define BTN_EN1 45 #define BTN_EN2 41 #define BTN_ENC 43 #define SDSS 53 #define SD_DETECT_PIN 49 // Pin 49 for display sd interface, 72 for easy adapter board #define KILL_PIN -1 #define STAT_LED_RED_PIN 39 #define STAT_LED_BLUE_PIN 37
07-10-2017, 10:26 PM #4
Is the pins.h file wrong? The RAMPS pin file is probably the best tested one. 1/2 of the people use that one. If it has an error in it... We need to get that fixed ASAP.
07-10-2017, 11:15 PM #5
Well, I think so. The manual provided by Panucatt has the RAMPS pins defined, and the default ones weren't correct.
Look at the last page:
http://panucattdevices.freshdesk.com...nts/1043587235
07-11-2017, 12:06 AM #6
Can you post your modified pins.h file here? Or at https://github.com/MarlinFirmware/Marlin/issues would be OK too. With a modified pins.h file that is working for you... It should not be too hard to get this rectified.
07-11-2017, 09:41 AM #7
pins_RAMPS.h
File is attached above. This gives me a functional LCD.
07-18-2017, 05:52 PM #8
After some time using Marlin 1.1.4 here is my pro con list compared to Repteier 0.92.9:
Pros:
Autoleveling/Autocalibration works quite well.
Buffer management helps out with complex g-code and 8bit processors.
Cons:
No Z Babystepping in situ from LCD.
No method for manually setting Z height from LCD - auto only.
No web/gui configuration. Took me a day to get my config files all correct.
The quality of the prints seem nearly identical...except for the fact that Repetier 0.92.9 hiccups on my 8-bit processor causing some pretty nasty "zits" and Marlin 1.1.4 does not.
07-18-2017, 07:12 PM #9
Yesterday, 01:26 PM in General 3D Printing Discussion
