Results 1 to 9 of 9
11-24-2014, 02:32 PM #1
- Nov 2014
- 5
Can Filtration Prevent Air Quality Health Issues?
I am currently in a group project researching the need for a filtration system for 3D printers. Does anyone have any experience or some personal opinions on this subject?
~Nick
Fourth Dimensions
11-24-2014, 03:06 PM #2
- Jan 2014
- Oakland, CA
- 935
It wouldn't hurt to try, but most FFF printers aren't enclosed (someone has a patent on enclosures for these things) so it would be hard to capture and filter the air around them. There has been some concern voiced about the toxicity and endocrine effects of the heated plastics used, even PLA, which is generally thought of as safe because it's derived from starch. Here's a link: http://www.motherjones.com/environme...n-plastics-bpa
However, given the very small size of the particles emitted, it's hard to imagine what sort of filter would be able to remove them and be practical and affordable as well: http://spectrum.ieee.org/nanoclast/s...ld-pose-a-risk
Andrew Werby
www.computersculpture.com
11-24-2014, 04:36 PM #3
- Jan 2014
- 462
There is a very good article here http://3dprintingindustry.com/2013/0...t-ventilation/ about ultrafine particles (< 100 nanometres in diameter) emitted by 3D printers. The upshot is that there is every possibility that there are negative health effects. Printing with a single PLA printer released roughly the same quantity of UFPs as cooking with an electric frying pan. Not enough is known about the precise chemical makeup of the particles to properly assess their health affects, but the size itself presents an issue.
The best filter I'm aware of that's reasonably commercially available are the HEPA filters used in some vacuum cleaners. These are rated to remove 99.97% of 0.3 micrometer (or 300 nanometer) sized particles from air passed through them http://en.wikipedia.org/wiki/HEPA. Unfortunately, that means they're no good for our purposes.
There are new HECA filters coming out that are specially designed for filtering UFPs. They have applications in cars, but I've not found any that are readily available http://www.acs.org/content/acs/en/pr...side-cars.html http://ceramics.org/ceramic-tech-tod...ion-making-too. Interestingly, it seems that UFPs can affect decision making.
11-25-2014, 02:29 PM #4
After talking with an Industrial Hygienist about this - someone who measures air quality and helps determine appropriate filtration systems for a living - anything with both activated charcoal and a HEPA filter should help with the smell and any possible health effects as long as it gives you enough air flow at the print bed. Air flow is "enough" if you have the printer in an enclosed container or if you can feel a light breeze from the intake near the extruder.
I picked up an air cleaner on Amazon for under $50 and that's been helping quite a bit. I'll be printing an intake manifold for it to better direct the fumes to the cleaner.
11-27-2014, 01:16 AM #5
- Nov 2014
- 5
Andrew,
A U15 to U17 will be needed in order to filter these BPAs. We are conducting research for a school project that might lead to production if the need is identified. We have a CAD diagram of the prototype so far. The final presentation will be in December. Your thoughts are appreciated. Thanks for all the input.
~ Nick
Fourth Dimensions
11-27-2014, 01:28 AM #6
- Nov 2014
- 5
3dkarma,
Do you think filters rated U15 - U17 are not the solution for this issue? Hoover has some filters that address this very issue. I did see the UFP can affect decision making. Seems like a lot of facts to consider when standing around a 3D printer.
~Nick
Fourth Dimensions
11-27-2014, 01:29 AM #7
- Nov 2014
- 5
Would you consider an off the shelf solution?
~Nick
Fourth Dimensions
12-27-2014, 08:59 AM #8
- Jun 2014
- 349
Thingiverse has a lot of filter holders you can put in or on your printer. Also I remember seeing a new printer that had a built-in filter on the back of the unit.
12-28-2014, 12:47 AM #9
- Jun 2014
- 3D Printer Tellus
- 83
MBot 3D have a build in filtration system for smelly ABS.
I have not tried it but it got a review of 8/10. I am contacting them to sell it on 3Dfilamenta Marketspace, just wainting for some answer before publishing it
