Results 1 to 10 of 10
11-08-2014, 09:00 AM #1
- 349
No warping, no smell, PET filament
Here is a summary of PET:
Also known as polyester
No shrinking or warping
No smell
Does not degrade in water
FDA approved for food contact
Does not absorb water
Not brittle
Is the most recycled plastic
Made Solid - from Matter Hackers, in California USA:
http://www.matterhackers.com/store/3...lack-pet-175mm
Made Solid - from California USA:
http://shop.madesolid.com/products/m...t-1-75mm-1-lbs
Colorfabb XT - from Netherlands:
http://colorfabb.com/xt-black
Colorfabb XT - from Printed Solid, in Delaware USA:
http://www.printedsolid.com/shop/175-3/xt-amphora/
Taulman T-Glase - from Matter Hackers, in California USA:
http://www.matterhackers.com/store/3...-t-glase-175mm
Eco PETG - from China (must email to order):
http://www.ecoreprap.com/pro/petg-filament
Reprap PET - from Denmark:
http://reprap.me/plastic/master-filament.html
11-08-2014, 11:05 AM #2
- Aug 2014
- Montreal, Quebec
- 576
I have a question.
Can they really guarentee the no shrinking? I am printing really big object 10". I am assuming you have printed them, so what is the catch beside the low glass transition temperature?
11-08-2014, 01:24 PM #3
- new jersey
- 752
Every formula of pet is different but as a general rule it warps about the same a pla. The advantage over pla though is strength, insane layer bonding on most and a glass point very close to abs.
11-08-2014, 08:41 PM #4
- 349
And most of the reports I've seen have said the warp is even less than PLA.
08-30-2015, 05:22 AM #5
- 349
Update:
No shrinking or warping.
No smell.
No enclosure required.
Build plate can be heated or not (depends on brand).
Can be printed on glass without any glue*
Does not absorb water or moisture from air, so no storage container needed.
Clear color is the most transparent of all filament materials.
Is much "tougher" that PLA or ABS; will bend before breaking.
Uses about the same extruder temps as ABS.
Does not need a print cooling fan like PLA does.
Also known as Polyester, PETG, PETT, PET+
Is what most soda pop bottles are made of.
Does not degrade in water.
FDA approved in the USA for for food contact.
Not brittle.
Is the most recycled plastic.
Prices are coming down, and some are about the same as ABS.
Test model: http://www.thingiverse.com/thing:990484
Printing video: https://vid.me/eEIW
Result video: https://vid.me/eEUW
Current places carrying PET:
eSun - from Intservo, in North Carolina USA:
http://intservo.com/products/esun-pe...iant=942259463
*opaque black is tested to print onto glass without any glue at all;
stays attached above 80C, and pops off at room temp.
eSun - from Intservo on Ebay, in North Carolina USA:
http://www.ebay.com/itm/221745555099
Alchement - from New Jersey, USA (choose PET from the menu):
http://www.ebay.com/itm/321625926855
RepRapperTech in Hong Kong:
http://www.reprappertech.com/3d-prin...ment/petg.html
Made Solid - from Design Box, in Ohio USA:
http://designbox3d.com/products/madesolid-pet-filament
Made Solid - From Australia:
http://thinglab.com.au/shop/3d-print...d-pet-filament
Taulman T-Glase - from MakerGeeks, in Missouri USA:
http://www.makergeeks.com/tpe3dprfibl1.html
Taulman T-Glase - from Imprinte 3D, in France:
http://www.imprimante3dfrance.com/en/pett.html
http://reprap.me/filament/petg-1-7mm
Gizmo Dorks - in Los Angeles, USA:
http://gizmodorks.com/petg-3d-printer-filament
Various:
http://www.microcenter.com/search/se...a-Micro-Center
3D Prima, from Sweden:
http://www.3dprima.com/en/filaments-...l-natural.html
08-30-2015, 12:14 PM #6
Okay - has anyone else used the colorfabb xt ?
Because it stunk up my workshop much worse than abs.
Yes it printed well, clean and sharp and it was tough, stiff and flexible enough for the parts i made. But by god did it smell when printing.
It's the only pet I've tried so far - but no way in hell could it be called odour free.
08-30-2015, 02:10 PM #7
- 349
Wow first Ive heard of this. Maybe it's really something else.
08-30-2015, 07:22 PM #8
- new jersey
- 752
i have printed a couple spools of it. i noticed no odor whatsoever. what was the color? maybe the colorant was giving off the odor...just a guess. i used black and white. while xt is nice its not my favorite pet.
05-07-2018, 02:05 AM #9
- May 2016
- 14
Actually the warp of petg is higher than PLA.
05-16-2018, 08:26 PM #10
- May 2018
- 11
Filament PM (Prusa) PETG from Canada https://3dcustom.ca/filament?olsPage=t%2Fpetg
Which 3d printer for small...
03-27-2024, 05:24 PM in General 3D Printing Discussion
