Thread: Best 3d image to print file
04-06-2025, 06:39 PM #1
- Apr 2025
Hi guys, I am trying to do 3d coins to print. I had a few designed but it has just gotten too expensive. I can make the image, but I need a program that will do a two-sided image to print file converter. What would you recommend. It has to have great relief and user friendly. I am not a designer who can write code. I tried a couple but the coin look was rough at best. It sunk the design on parts. and the edges were rough. I need something this nice. This is just side one. Here is the one I and trying to do front and back
04-07-2025, 02:23 PM #2
- Jun 2022
- The great state of Texas
- 176
You have to use a height map/depth map to create proper geometry to be able to print correctly. Workflow: 1. Use an AI depth map generator to create a height map of the image. There are several free ones online. You want to use the best image quality for the opportunity to get a good depth map. 2. Use a 3d modeling software or slicer to generate geometry from the depth map. My goto is Blender but CURA can also do it. 3. In a 3d modeling software combine the two sides. 4. Export as StL and print. I know it sounds complicated but once you figure out the workflow its fairly easy. This is my personal workflow for my cnc pattern making for using AI tools. Good luck
Login Error
06-10-2025, 06:03 PM in Site Related Discussion & News
