    Bracket print fails at same point in the print
    Hello Everyone,
    I am new to 3D printing, but I have designed and printed several items successfully.
    I have designed a bracket that will slide over two cylindrical posts, and has a plate with two holes to mount another object.
    I have printed this 3 times, and each time the print fails at the same point, and I get a “stepper error”. Once the printer just stopped when the error occurred. The other two times it printed a bit rat’s nest of thread as it tried to finish the print.
    The print proceeds upwards printing the green bar and the light blue cylinders just fine. It prints the dark blue plate up until it reaches the very start of the first mounting hole that it comes to, below the large cutout within the dark blue mounting plate.
    It always crashes at the same place!
    I wonder if there is any software that can analyze the .3mf or .stl file and flag any problems?
    I am using a Monoprice IIIP printer.
    I used Microsoft Windows 3D Builder to make the design.
    I used the Cura version that came with the printer, (I don’t see a version number). I tried printing twice with 100 % fill, once with 60 % fill. I have “Fix horrible” all un-ticked in the Expert Pulldown menu.
    Any thoughts on why this design keeps crashing, at the same place, each time I try to print it would be much appreciated!
    Any (freebie) analysis software recommendations would be appreciated as well.
    (Or, if you are bored, you could try printing the item and see if it prints successfully for you!)
    My “Plan B” is to re-design the part as two pieces, the green bar and its mounting cylinders, and then the dark blue mounting plate separately, and then have a hole to bolt them together, but I really would like to learn why this part fails.
    I have attached the .stl file. I do not see how to attach the .3mf file.
    If I can provide other info please let me know.
    Thank you,
    JC
    Attached Files Attached Files
    Technologist
    Jun 2022
    The great state of Texas
    Hi. I do not see anything obviously wrong with the model. Blender 3d has a rudimentary 3d print model analysis tool that is built in. You do have to enable the addon for it to be visible. Goto Edit > Preferences > Get Extensions > 3d Print Toolbox [checkbox] I did throw the model into my Bambu P1P and it printed with no issues. I would try printing at a different orientation or maybe a different filament roll.
    Hello OG56,
    Thank you for your time and help.
    It is very much appreciated.
    When the print stopped, three times, at exactly the same spot, I suspected that there was likely a problem with the original model, or with the slicer processing the model.
    It is good to hear that it actually printer fine for you, that is actually very helpful information.
    I appreciate your suggestions, as I've not been doing this long enough to recognize common problems, and know the best options for resolving them.
    I will re-orient the object and try a new filament roll and see what happens!
    Thank you,
    JC
    Student
    Mar 2025
    Taxachusetts
    Yep just looking at orientation of print it will fail on that overhang, reorient.....supports needed. I would flip it back 90 from perspective of image you have posted.
