Thread: Anycubic Slicer Next
03-07-2025, 07:32 AM #1
Anycubic Slicer Next 1.3.3 For Windows
What's new:
1. Added "Skip Part" feature (Currently for S1, version ?2.8.4.3)
2. Improved login region prompts.
3. Fixed temperature errors when leveling with multi-color filament box.
4. Enhanced overhang printing quality
5. Added support for Anycubic Kobra 3 Max and new filament profiles:
PLA Silk @Anycubic Kobra S1
PLA Luminous @Anycubic Kobra S1
PLA Silk @Anycubic Kobra 2 Max
PLA Marble @Anycubic Kobra 3
6. Optimized layer change and pause commands for Kobra 2 Pro/Plus/Max
03-21-2025, 09:17 AM #2
Yesterday I found the newest Orca Slicer 2.3.0 RC Build 79a5a9b build and printed using a USB Flash drive.
This means maybe the Anycubic Kobra 3 users have 2nd chose of slicer that will print models with a Anycubic Kobra 3 Combo
Orca Slicer 2.3.0 RC was released 6 hours ago.
Well did not change colors will have to look into this.
__________________________________________
OK today I tried again by placing 3 different color models on the same build plate. the results were great.
I printed 3 completely different color model gears of spiral graph on the same build plate at the same time..
So my thanks to Orca Slicer 2.3.0 RC for finding a way to get Kobra 3 combo printing in color..
now maybe I can figure a way to get it to print using my painted objects.
I do not believe that posting a Photo does any justice try to print as I have stated an you will see.
I swear I did a color print using Prusa slicer but could never could duplicate, now I will try duplicating this again.
Using this same method of printing 3 Separate color models on the same build plate.
https://github.com/SoftFever/OrcaSli.../tag/v2.3.0-rcLast edited by Roberts_Clif; 03-21-2025 at 09:53 AM.
03-22-2025, 07:07 PM #3
Here we have a Painted object shown in the photo below.
If the Painted is in Object mode then they will have a place to select/change the filament.
Painted Object
Else if they do not have, then the filament will not change in this global mode.
03-23-2025, 07:54 AM #4
Hi
I have been looking for a users manual for Orca Slicer 2.3.0 or anything even close as to allow me to use the full potential of slicers.
Would be happy to see this in any form pdf, you-tube videos just would like to learn everything that can be done with this slicer.
QIDI Q1 PRO cleared clog but new...
04-21-2025, 01:46 AM in Tips, Tricks and Tech Help
