Thread: Please help dial in my printer
02-11-2025, 09:16 PM #1
- Feb 2025
Hello everyone. I am new to 3d printing, and I am trying to get my Elegoo Neptune 4 PLUS dialed in. I've had some struggles out of the box with bed adhesion with both PLA and PETG, and crazy stringiness, layer adhesion and boogers with PETG which is probably expected for a noob. Anyhow, I installed OpenNept4une last week and have been maticulously going through all of the setup and adjustments in the wiki over there. I printed a scraper I found over on Printables to help get things off the bed, and I'd like your comments about the print quality and what I should look at tweaking to make it better.
Using Orca slicer, printed in dried PETG (10% humidity), 4mm nozzle, 235c, layer height .2mm, flow ratio 1.08, PA .124, retraction length 5mm, z-hop .5mm. 3 walls, 3 top layers, 4 bottom, 10% gyroid infill. 20mm first layer speed, 60mm outer wall speed, 200mm inner wall speed.
Stringing on this was much less than I've had in the past, but it might just be the model. I think the top of the print looks like crap. What do you all think? What should I look at tweaking to get it even better?
Thanks in advance for the help!
02-11-2025, 09:40 PM #2
- May 2018
- 627
slow down.. try 40mmS.. infill 35%, layer height .3
02-12-2025, 10:21 AM #3
- Feb 2025
Thank you for your suggestions. I tried these settings and the print is not much different. Any other thoughts? Another question. I have the top surface pattern set to rectilinear, but it doesn't appear that there is any sort of rectilinear pattern on the top surface. I probably am not understanding the setting.
Thanks again!
SGCAM_20250212_082911722.jpgSGCAM_20250212_082917804.jpgScreenshot 2025-02-12 at 9.37.44?AM.jpgLast edited by miatawnt2b; 02-12-2025 at 10:39 AM.
02-15-2025, 09:00 AM #4
- Jun 2020
- South Carolina
- 59
Look into linear advance. https://marlinfw.org/tools/lin_advance/k-factor.html
Getting this dialed in helped me a lot.
Horizontal expansion is another setting that can help with over extrusion.
02-18-2025, 06:51 AM #5
- Oct 2023
- 11
What does "dial in a printer" mean?
02-18-2025, 08:36 AM #6
- May 2018
- 627
02-18-2025, 10:02 AM #7
- Oct 2023
- 11
QIDI Q1 PRO cleared clog but new...
04-21-2025, 01:46 AM in Tips, Tricks and Tech Help
