    Any way to use Variable Layer Height AND flush into object?
    Is there any way to use Variable Layer Height AND flush into object if the latter is not the same model as what you need variable layer height for in Bambu Studio?
    Basically, I want to print out a few copies of a model. Normally when I do this I also include a fidget toy or Christmas ornament to flush the purge to.
    This time, I want to use variable layer height on the model since it has a rounded top. Unfortunately if I set that on the models, I get a The prime tower is only supported if all objects have the same variable layer height error. That's all fine and good, but the prime tower is required to use the "flush into object" feature to my understanding.
    Is there any way to solve for this? Can I somehow "copy" the layer heights from my model to the flush objects since I don't care about their layer heights? Googling around hasn't turned up any answers unfortunately.
