Thread: Vertical dunes problem
11-19-2024, 07:53 AM #1
- Nov 2024
- 2
Hi all, I noticed my 3d printing results have "vertical dunes". And I can't comprehend how this can be. This happens in the surface that is close to a curve. It sometimes also happens on the curves. Some curves do not have it as we can see on the right side of the printed model in the picture.
Also, the top surface seems so "stringy". Is it perhaps a flow problem?
Did anyone encounter this problem before? Or know how to fix this?
As a note: I printed this in relatively fast speed with Anycubic Kobra Neo. Normal speed seems to have this problem as well, though less influence. This did not happen before. The filament is in the state of almost over.
11-20-2024, 04:36 AM #2
- Nov 2024
- 2
Got it. I will try stabilizing the frame, etc. Do you know how filament nearing the spool's cause the stringy top? Isn't the amount of filament entering the nozzle is just the same as when the spool's still full? Funnily it is actually the case of mine - spool's almost done. But, I haven't made sense of this.
Design Approach and Filament Reco...
01-19-2025, 05:21 AM in General 3D Printing Discussion
