10-31-2024, 08:44 PM #1
- Oct 2024
- 2
Problem implementing G34 to Dual Z Axiz alignment
Thank you in advance if you are able to help me out sorting this strange issue,
Once i run G34 or Z auto-align from Motion Menu my left Z motor reads fine at left center of my heated bed but for some reason my second Z axis reads at front center of my heated bed, moving the Y axis all the way back.
It wont even run the entire X to the opposite direction it just stops at center and moves the Y all the way back.
I have recently upgraded my CR10 to a double Axis, this printer has been modified with a skr 1.4 32 bit board and BLtouch but has been working flawlessly.
My marlin version is 2.1.1 and i have installed my second Z in the E1 driver port with a TMC2208 , so i have 5 of these in total in X,Y,Z, E0 and (E1, now second Z axis) In configuration.h i have enabled the stepper motor driver type for the Z2:#define Z2_DRIVER_TYPE TMC2208
And in configuration_adv.h i have,Set same current for both Z and Z2 axis
and uncommented: #define Z_STEPPER_AUTO_ALIGN
The next is not in Marlin Version 2.1.1 since it relies in Z2_DRIVER_TYPE TMC2208 to know a second Z motor/driver is installed.
#define NumZ_stepper_drivers 2
The following parameters have been uncommented and commented back in order to provoke a different interaction, so far with no avail, its not recognizing changes in any of the following:
//#define Z_STEPPER_ALIGN_XY { { 27, 107 }, { 229.5, 107 } } (the coordinates have been changed several times, i only get an error in the compilation if the values overshoot the bed size.)and
//#define Z_STEPPERS_ORIENTATION 0
* 2 Steppers: (0) (1)
I have been experiencing with these to no avail, still having the problem (it seems the system is choosing between option 0 and 1 and running the 1 from (0) and the 1 from option (1)
I fell lost.Please let me know if you have experience fixing this issue or have any idea of what may be causing it.
11-01-2024, 10:52 AM #2
- Oct 2024
- 2
It seems this was a Marlin´s Version related Bug, I just ported all my configurations to Marlin 2.1.2.4 with the bug fixes patch and it seems to be working correctly.
TPU anti-adhesion
01-15-2025, 08:41 AM in General 3D Printing Discussion
