10-31-2024, 11:23 AM #1
- Oct 2024
Air compressor keeps running while 3D printing
The air compressor constantly runs creating water drainage issues. We have an Industrial Air 80 gallon compressor (80 gallons @ 100 psi). The printer is: EOS P110 velocis (Demand: 5.9 CFM @ 150 psi.
10-31-2024, 11:53 AM #2
- May 2020
- 695
Considering that you have posted about an air compressor in a forum dedicated to 3D printing I assume you will know where to get a discombobulater, if you get one with a double joint giggle pin you should then fit that on the compressor exhaust and run it at maximum revs.
I'm sure this will solve the problem.
An alternative would be to have someone 3D print a twin relay dinglebang.Last edited by Bikeracer2020; 10-31-2024 at 12:25 PM.
10-31-2024, 05:23 PM #3
- May 2018
- 608
get an auto drain valve
Bizarre Sudden Stringing
01-29-2025, 09:16 AM in Tips, Tricks and Tech Help
