Thread: Feeder Tension
10-25-2024, 03:39 AM #1
- Oct 2024
- 5
Feeder Tension
What should I keep feeder's pinch roller tension to?
I have adjusted tension on my ultimaker 2+ and now I can see little marks of knurling which is present on one pinch roller.
I wanted to attached photo of filament after it goes through feeder but couldn't find option to attach. Is my tension too high ? (As it is leaving marks)
10-25-2024, 05:29 AM #2
- May 2020
- 689
It's called 'manage attachments' lower down the page where you type in your post.
10-26-2024, 04:25 AM #3
- Aug 2024
- 11
So I was getting these marks and I felt like I was also having issues with my prints due to the feed rate of my filament. Like you I was getting scaring on the sides of my filament that I would notice when changing colors or filament. I ended up printing a roller setup with bearings that allowed my filament roll off of the spool more freely. I was using mostly cardboard rolls on a hard plastic hanger. I did a few other things to this printer for filament feed too, because it was eating into my filament empty sensor. I knew it wouldn't last too long if I wasn't able to reroute it. The roller was the thing that helped the most with filament flow for me.
What is the best material type for...
12-06-2024, 01:16 PM in General 3D Printing Discussion
