Thread: Hole for heat set insert
08-08-2024, 01:42 PM #1
- Aug 2024
I'm looking for help with how to prepare a print in Prusaslicer for a heat set insert. I've created separate posts for the inserts and added them as a modifier to my main part in Prusaslicer, but they always end up filled in, instead of having a hole in them for the insert. I suppose I could drill that out, but not exactly what I'm trying to do.This probably wasn't the best description, so I've attached a picture of the modifer I created, and a picture of the modifier in the main object - you can see the internal of the modifier is filled in by the main objects infill..
Thanks!!
Joel
08-10-2024, 11:39 AM #2
- Aug 2024
If anyone is interested, I got my answer over on the Prusa3d forums: https://forum.prusa3d.com/forum/prus...t/#post-718495
Joel
layers start moving
12-01-2024, 07:41 PM in Tips, Tricks and Tech Help
