Results 1 to 10 of 11
07-06-2024, 10:39 PM #1
- Dec 2020
- 16
the box bottom printed as a layer of net even transparent? not a wall as designed?
Hi all.
The printed box don't have a bottom, no matter the thickness that was designed 0.5 or 1 mm, why so and how to fix?
Thanks.
Adam
07-06-2024, 11:32 PM #2
- May 2018
- 582
Slicers have settings for number of bottom layers, number of top layers, number of perimeters... if zero then you get no layers..
07-07-2024, 10:30 AM #3
- Dec 2020
- 16
thanks.when said "bottom" cause of the part put that face down when printed (picture A), actually the "bottom" is a real wall of the part, one entity of the part. does the Slicers consider the floor as bottom always no matter what it is? and if let's say put the part side stand, what can get of the new 'bottom' (picture B)?picture A:https://ibb.co/48pMmXy picture B:https://ibb.co/mv2tdd0used image hosting cause of not find image icon here in reply.
07-07-2024, 10:43 AM #4
- May 2020
- 685
07-07-2024, 11:05 AM #5
- May 2018
- 582
what your part looks like does not matter.. the system works from the build plate up .. Bottom is what touches the plate, top is what has nothing above the bottom. So if the part that touches the plate is 4mm tall and your layer is .2mm, and you are set to 3 bottom layers and 3 top layers and infill of 50% then you get 3 layers that are 100% then layers that are 50% solid, then the last 3 layers would be solid..
07-07-2024, 11:08 AM #6
- Dec 2020
- 16
Bikeracer2020 Bikeracer2020 is offline ? thanks.picture Aicture B:
07-07-2024, 02:42 PM #7
- Dec 2020
- 16
07-07-2024, 03:13 PM #8
- May 2018
- 582
Can you change the orientation of the part by rotating it 90 digress so the point is up.. you can not print over open air..
In the slicer the is a way to put whatever surface you want on the build plate.. no idea what you are using but all slicers have the ability
07-08-2024, 10:40 AM #9
- Dec 2020
- 16
Tested with different filling density 15-40-50, and bottom/top layer 5-6, try to get better bottom failed. I used Easythread to generate Gcode from STL.1. is it possible to set different filling density in same part? like: bottom 100% / Intermediate Structure 20% / top 50%?2. any better software?
07-08-2024, 10:48 AM #10
- Dec 2020
- 16
Kickstarter campaing LEGENDARY...
Today, 12:54 AM in Free Self Promotion
