Thread: Help with boolean difference
03-24-2023, 05:15 PM #1
- Mar 2023
Hi,Im trying to use half of the attached meshes to make an imprint on a surface (like a chocolate box). I struggle to get it to work though. Have tried Boolean Difference inh Meshmixer and Blender, but does only pruduce non working results.Thanks for your help!Martin
03-24-2023, 07:33 PM #2
- Jun 2014
- 869
I selected the Queen component, then performed a plane cut and aligned the cutting plane to the monolith. On execution, I selected both components and performed Combine. The result is attached. There was one flag within Analysis>Inspector but selecting it for repair did not cause any apparent damage. Hope this helps.
03-24-2023, 07:34 PM #3
- Jun 2014
- 869
Okay, that was WRONG. You're asking for the difference and I did a combine. Sheesh. I'll get back on it in the morning.
03-25-2023, 08:28 AM #4
- Jun 2014
- 869
Now that I'm awake, I used Fusion 360 to import both meshes, used Mesh/Modify/Combine and created the attached file. It passes Meshmixer's Inspector.
Hope this is what you wanted. If not, let me know where the misunderstanding lies.
How to design buildings for model...
09-23-2023, 05:15 PM in 3D Modeling, Design, Scanners
