03-19-2023, 06:20 AM #1
- Mar 2023
Filament not sticking on Malyan ma10
Hi guys, I’ve only recently gotten a Malyan ma10 mini and have had a few issues getting going. Currently, filament appears to not stick and is dragged along the build plate, creating a messy first layer made of out of place lines and loose squiggles. This means there is little contact to the plate, so the print dislodges and moves around.
The few layers which do completed are uniform and as the print should be, but the first layer refused to do this
I am using pla at 200-215 with base at 60 and fan 100%, but can’t seem to resolve the issue
Any help would be appreciated, many thanks
03-19-2023, 06:23 AM #2
- Mar 2023
Also want to mention I was able to do prints okay without this issue, but then had an issue with what seemed to be gcode calibration where the printer would start dumping filament in the top right corner instead of on the base plate, but this is resolved by turning it on and off between each print
it was after the first few prints that both these issues began to show
