11-22-2022, 11:07 AM #1
- Nov 2022
Simplify3D produces stuttering curves on Makerbot Replicator Z18
I have recently switched from slicing on the MakerBot cloud platform to slicing with S3D, but I noticed that the curves are not printing as well as when sliced on MakerBot cloud. It appears that, when sliced with S3D, the printer travels through the curved section with a stuttering movement of short segments instead of a continuous curve as it does when the model was sliced on MakerBot cloud. Print sliced with S3D also takes significantly longer to print. Is there any setting I can modify on S3D that will fix the problem? I tried the ArcWelder plugin, but I don't think it works with .makerbot output format. These are images of the two test prints printed on the same printer (MakerBot Replicator Z18, firmware version 2.6.2) Makerbot Cloud Print: https://imgur.com/0qccfEU S3D:https://imgur.com/UHbCQsI Comparison: https://imgur.com/nbtXdG3The Setting used on both prints: 2400mm/min outline speed, single outline with 0% infill (vase mode), 0.2mm layer height, 200 °C, Thanks a lot!
11-22-2022, 11:08 AM #2
- Nov 2022
Sorry about the poor formating, I don't know why it didn't recognized the line breaks.
Yesterday, 01:26 PM in General 3D Printing Discussion
