Thread: Make up
11-22-2021, 08:49 AM #1
Make up
Can you guys recommend any makeup products I can use? I train a lot and consequently sweat a lot so my skin is in terrible condition
11-22-2021, 10:22 AM #2
Saaaame. I used to have this problem a year ago but as I stopped working out it's gone. However, don't make it the reason to stop doing sports because you can use some cosmetics to fix your skin but you can't do it to fix your health. Good luck with your problem
11-22-2021, 11:32 AM #3
- Nov 2021
- US
- 5
My lashes are the biggest problem for me during training so I had to use tons of stuff in order for it not to fall appart. However, after buying this lash lift kit I litteraly forgot about it. Man I recommend it, especially if you train as much and as active as I do
11-23-2021, 08:42 AM #4
- Nov 2021
Make up
The use of makeup has been around for several centuries. In the 1880s, Queen Victoria declared the practice to be vulgar. Modern makeup products contain a variety of chemicals, including coloring agents, emulsifiers, and fragrances. Preservatives keep the products fresh and usable for a longer period of time. Penhaligons Voucher Code colorants are usually made from mineral sources or can be derived from plants. Emulsifiers are chemicals that help the ingredients of oils and water mix.
Ender 3 V2 - Fried Mainboard via...
05-26-2022, 05:37 AM in Tips, Tricks and Tech Help
