Thread: Blobs - Not printing correct
06-02-2021, 08:52 AM #1
- Jun 2021
Hello
I purchased a Creality CR 6 SE about two weeks ago. The printer has been working excellent and I have done about a dozen prints using 3 different PLA filaments. Yesterday I switched over to a "Marble: effect filament with a heat range of 190-220c bed temp of 0-50c. I set my file to print at 220, then 210 and finally 200. I'm getting blobs of filament and an over all crappy base (I stopped printing after 10 minutes). I'm assuming the blobs are because the temp is too high? The other pieces I printed on the other filaments were at 200 and looked great. Base layer was very smooth. Attached are a few photos before I canceled printing.
The bed is level, I confirmed this after cancelling the print with the marble filament and switching back to the other filament I had success with. Starting printing again it everything is fine
Thanks
07-20-2021, 08:10 PM #2
- Jul 2021
- 26
Your bed is way way way to close to your nozzle. Keep in mind that when you use different temperatures for different filaments, the thermal expansion will ruin your leveling. You must always level for the first layer settings that you are using. For more info on how to control stringing and blobbing in particular, take a look at my blog.
Which 3d printer for small...
