Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Technologist
    Apr 2021
    Just to expand on the above, you don't need to do all the mods I have done to get it printing. It may print fine for your application out of the box. I did those mods because I need it to be a workhorse, and to use the same profiles as my other machines.
  2. #12
    From what i read sapphire is faster than twice as fast in printing. It's true? How much print quality do the two differ?
  3. #13
    Technologist
    Apr 2021
    No idea. Tron typically has very slow settings in its firmware. I don't have a Tron X5SA though. I have a custom printer, built using the Tron X5SA Pro's frame.
  4. #14
    convinced that the sapphire 1.1 cost almost as much as the tronxy,instead was version 1.0. at this point more than decided for the tronxy x5sa pro. Which mainboard should I take? the manufacturer says he mounts different kinds..
  5. #15
    Technologist
    Apr 2021
    Got a link? I’ve never seen options for main board type from tronxy. The board is usually a chitu board, setup for that particular machine (and sometimes with quite varying specifications).
  6. #16
    xxxxxxxxxx
  7. #17
    Technologist
    Apr 2021
    You mean the silent drive option? Pretty sure all of the X5sa pros have silent stepper drivers.
  8. #18
    I don't know. I was wondering for this. I would like to get the best one if there is and obviously upgradeable to marlin..
  9. #19
    Technologist
    Apr 2021
    Well, I think those are all the same. That cheapest listing is for an X5sa, or X5sa pro. So make sure you choose the right one.
